Old 11-30-2011, 12:59 PM   #41
dude
dude's Avatar
Default Re: Flathead build
If we hadn't moved from the horse to the Model T,we would this be shoveling horse poop. That's pretty simple. Love what you did with the new tech.
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 11-30-2011, 01:02 PM   #42
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Junknshit View Post
Thank you V8 COOPMAN,you probably just saved me from getting banned from the Barn. You said what I was putting together to post in a much nicer way than I was going to. Ol Ron, Virgel, a guy that posted about cams, I think Pete, and others, and now hopefully Kerker, What a great bunch of knowledge being shared. I'm 69 and I still suck up all that I can.
Junknshit...Mine was also the "clean" version. Didn't want the "few" to get their feelings TOO hurt. DD
Old 11-30-2011, 02:04 PM   #43
kerker
Vergil
The injectors I looked at were at www.asninjector.com To the members that support develoment, thank you. Those that don't, that's ok too.
kerker is offline   Reply With Quote
Old 11-30-2011, 05:11 PM   #44
kerker
Smile Re: Flathead build
This is an early version of my flathead. Runners are too short for the street. ( my humble opinion only) Looks neat, but I wasn't satisfied with
performance. For the "traditionalists" I like this too, but not the plug readings that came with it. When I talked to Edelbrock, I was told that it was the nature of the beast. Might be Ok at high RPM'S. Looks good , runs OK. OK is not good enough.
Dick in Havasu
Old 11-30-2011, 05:35 PM   #45
Vergil
Vergil's Avatar
Originally Posted by kerker View Post
Vergil
Thanks Dick, The link above didn't take me to a site, is this the injectors you was referring to?
http://www.asnuinjectors.co.uk/index.htm
On the injection setup in the picture above, were the ports in the intake manifold connected with the equalizer runners between or were they plugged to make it a port per cylinder (8 itb's)? I have one flathead setup with the equalizer runners and wet manifold which doesn't give the performance as the port injection and equalizer runners blocked to make it 8 itb's. The throttle plates are 1 3/8" straight through with no restriction. BTW the setup in the picture looks sweet anyway, impressed.
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 11-30-2011, 07:14 PM   #46
kerker
All TB's are tied into the aluminum tube that is centered between the
TB's. They are the 3/8" black tubes that come out of the TB's. I tried jetting them etc etc, but now they are open to the plenum. I needed vacumn for the Columbia. I have a seperate line running to another tank for the
Columbia. If you get out of the city limits with a flatty, the Columbia makes it nice for cruising.
Dick in Havasu
Old 11-30-2011, 09:08 PM   #47
kerker
Vergil
Try asnuinjectors.com
Dick
Old 12-01-2011, 04:02 PM   #48
kerker
Vergil
I found some pictures that might explain the balance tube for the throttle bodies. These are the tubes I played with some jetting. ( air jets) You can also see the idle jets from a 97 I used to balance the bodies. It bleeds air from the top and comes out past the plates thru the opening I left on the bottom of the reducers. Even though the throttle plates I made held water, the linkage was difficult to get perfect. This is a poor example of how to build linkage. Next one will be better. This also an example on where not to place your injectors. They are too far from the valve for good accel pump action. cruising, they are OK. Ok is not good enough. The picture with the rubbers tubes comming out of the bottom is how I reduced the runners. Surgical tube with spring supports. The rubber was centered with a support on the round entry side. The void was filled with Devcon. The rubber tube allows you to go from round to oval runners.
Dick in Havasu
Old 12-01-2011, 04:28 PM   #49
Vergil
Vergil's Avatar
Dick I tried http://www.asnuinjectors.com/ and it takes me to a generic site. When I was asking about the port equalizers I didn't make myself very clear. I was referring to the engine in post #44, sorry. All of your builds are beautiful even the "okay" ones.
Vergil
Old 12-01-2011, 05:50 PM   #50
roseville carl
roseville carl's Avatar
Ouch just looked at this post........Damn that is beautiful!!!!!!!!
Great job.
roseville carl is offline   Reply With Quote
Old 12-01-2011, 07:19 PM   #51
Ronnie
Ronnie's Avatar
R
Ronnie is offline   Reply With Quote
Old 12-01-2011, 09:41 PM   #52
kerker
Glad you like it
