Old 06-20-2010, 01:51 PM   #8
Bubby Sharp in KY
Default Re: Two Model A's drive off the road today in French Lick to avoid hittings cars in f
Carl, Hydraulics may not be the answer , because if you lose one line the whole system fails! You can remove one rod and the mechanical will still work. Limiting factor is tire size if you have cast drums properly installed and the systems is up to par. Bubby Sharp in KY
Bubby Sharp in KY is offline   Reply With Quote
