Old 11-17-2011, 04:56 PM   #1
Paul from Maine
Paul from Maine's Avatar
Default How much voltage should you have between the distributer and plug?
How much voltage should you have between the distributer and plug? According to my NuRex spark voltage tester, I have 20,000 volts between the coil and the distributer cap. However, when I put the tester between the cap and the No. 1 plug, I was lucky to get a steady 10,000 volts. I have an ancient original cap that looks in good shape an an old rotor that looks good. Is this voltage drop normal? Should I be adjusting the gap between the rotor and the terminals in the cap? Should I buy anew cap and rotor?
Paul from Maine is offline   Reply With Quote
Old 11-17-2011, 06:58 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: How much voltage should you have between the distributer and plug?
I dont know how accurate the tester is , but a good running engine needs approx 5-8000 volts at idle total secondary ignition. Rotor and plug gap typically eat up 2-3000 volts in the gaps etc.
A new cap and rotor is always a good idea assuming the parts are quality parts.....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-18-2011, 06:39 AM   #3
Robert
The last time that I touched a spark plug connector,the 'delivery' that I received felt as if I had taken a dose of AT LEAST 500,000V...TWICE. Since then, I have been able to pick up small ferrous objects using the back of my hand. Also, I have been told that the compass in my friend's 60's Caddy swings in my direction whenever I travel through his neighborhood. HMM?!?!?
Robert is offline   Reply With Quote
Old 11-18-2011, 08:08 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Although it might be nice to know, as long as you get a spark at the plug it's enough.
Old 11-18-2011, 08:39 AM   #5
Kevin in NJ
Put you hand on the wire while well grounded.
If you just say ouch then it is weak.
If you say oh sh t then it is ok
If you say g d d m mf son of a b then it is real good.
If you wake up in the hospital then tell me what you are using cause it is real good.
