Old 06-15-2010, 04:14 PM   #21
FatDave
Default Re: Driveline vibration
Originally Posted by GreenMonster48 View Post
Once you take care of the safety issues, check out the steering stabilizer on this page.
http://www.lmctruck.com/icatalog/fa/full.aspx?Page=78
That's really cool.
I've never seen that before.
It's on my shopping list now.
FatDave is offline   Reply With Quote
Old 06-15-2010, 04:44 PM   #22
Marv
Marv's Avatar
Wink Re: Driveline vibration
Maybe it is just your tires. Bias ply nylon tires used to do that, until you drove a few miles and got the tires warmed up to remove the flat spots, from where it sat. Marv
Marv is offline   Reply With Quote
Old 06-15-2010, 04:48 PM   #23
Marv
Marv's Avatar
Smile Re: Driveline vibration
Dave i forgot to mention. Since you lowered your car, is it possible that your driveshaft is to long and bottoming out.
Old 06-15-2010, 06:20 PM   #24
0rg0
0rg0's Avatar
I went for a drive in this truck on Sunday afternoon. After we put shocks in it. It scared the shit out of me. I think you guys that suggested a total front end rebuild are on the money.
0rg0 is offline   Reply With Quote
Old 06-15-2010, 08:01 PM   #25
FatDave
I set the pinion angle after it was lowered... plus speed doesn't seem to affect it, but as soon as I hit a bump, or the vehicle goes a little off-kilter then she quakes like a son of a bitch.
... but not for long.
Old 06-15-2010, 08:29 PM   #26
Comet
Comet's Avatar
If it ran fine before lowering, then you need to look at the things you changed as a culprit. If it's the front, my guess is bump steer. If it's the rear, check your pinion angles again. That's where I'd start. I wouldn't just start throwing parts at it (although it sounds like you need some anyway). And definetly put shocks on the front before fixing any bump steering issues. Shocks alone will greatly help that issue.
Comet is offline   Reply With Quote
Old 06-15-2010, 08:34 PM   #27
Dave72dt
What type of front suspension do you have on it and how did you lower it? Bump steer is sounding more and more like it.
Dave72dt is offline   Reply With Quote
Old 06-15-2010, 08:58 PM   #28
Vergil
Vergil's Avatar
If you dropped the rear 8" and the front 3" your camber has changed and will give you the shakes.
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 06-15-2010, 09:51 PM   #29
Kurt in NJ
Kurt in NJ's Avatar
Did you check the caster angle when you changed the ride heigth ??--by lowering the front more than the rear you could have changed the caster angle to a much lower amount ---less caster will make the wheels more prone to shimmey.
