Old 08-12-2011, 06:39 AM   #1
34 GAZ
34 GAZ's Avatar
Default Trivia, what,s this recess for on my rear axle ??
I have a decent collection of rear axles but only one with this 1 inch wide groove on the drivers side . Top side is pretty deep and runs to the normal smooth outer curve at the bottom of the axle. Other side is normal smooth curve all the way around. Looks like a recess for a strap. Axle had 1940 backing plates. 3rd pic is the smooth side.
34 GAZ is offline   Reply With Quote
Old 08-12-2011, 10:12 AM   #2
flatheadernie
Default Re: Trivia, what,s this recess for on my rear axle ??
POSSIBLE CUT LINES FOR A COLUMBIA 2 speed instalation ? ernie n tx
flatheadernie is offline   Reply With Quote
Old 08-12-2011, 02:37 PM   #3
Mart
Mart's Avatar
Hi Henry. Never seen anything like that before.
Is that the one from the snowmobile conversion?? Is it narrowed perhaps??
Mart.
Mart is online now   Reply With Quote
Old 08-12-2011, 03:22 PM   #4
Brian
Brian's Avatar
Maybe some machinest has machined a groove in it in order to run it in a three point steady in his lathe? Brian
Old 08-12-2011, 05:24 PM   #5
34 GAZ
34 GAZ's Avatar
Is that the one from the snowmobile conversion?? Is it narrowed perhaps?? Mart.
G'day Mart, Not from the Snowmobile , not narrowed.
Ernie might be onto something & Brian too, Only thing is the recess thins out to zero as it curves to the bottom side of the axle.
Old 08-12-2011, 09:35 PM   #6
Lawson Cox
Lawson Cox's Avatar
I have never seen anything like that myself. Cannot hazard a guess as to who has done what to the axel housing over the past 70 years. Doesn't look deep enough to cause any weakness.
Old 08-12-2011, 09:50 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
Perhaps the metal was thicker than standard --but for the weld process to work properly it needed to be turned down some ---even part of an experiment for a new process.
Old 08-13-2011, 08:08 AM   #8
34 GAZ
34 GAZ's Avatar
Took another pic this arvo, do you see real old tack welds ?
Old 08-13-2011, 11:10 AM   #9
ford38v8
ford38v8's Avatar
I haven't seen that before, but one possibility is that it was the result of the casting mold having been modified. Many molds were used, producing slightly different results fore each mold.
Alan
ford38v8 is online now   Reply With Quote
