I don't think today Crower ever will do them.
Yes the Ardun might work with ex Chevy lifters with a connection arm, but the FH don't. I was into lathe bronze bushing and has a smaller diameter body inside where bearings is mounted and then a max diameter roller bearing. Bushing with a slot for the bearing and pressed into block. That might keep the bearing in place over cam. |
