Old 05-29-2026, 11:38 PM   #1
uncle buck
uncle buck's Avatar
Default 1932 cabriolet 1/4 panej
I have a friend with really ruff 32 cabriolet and we were talking about repairing it. Could a Brookeville roadster or United Pacific 5 window quarter panel be used to repair a 32 cabriolet 1/4?
Thanks, Dave
uncle buck is offline   Reply With Quote
Old 05-30-2026, 07:05 AM   #2
alchemy
alchemy's Avatar
Default Re: 1932 cabriolet 1/4 panej
The five window quarter would be closest. But you’d need to remove the big bead adjacent to the decklid, and rework the curve of the side beads where they come together at the back end. Not sure, but the door length could be different too, so a cut a change at the B pillar might be necessary.
Other than that, it’s a piece of cake.
alchemy is offline   Reply With Quote
Old 05-30-2026, 08:52 AM   #3
Karl Wescott
Karl Wescott's Avatar
The door length is slightly different from the 5 window. There is also a difference in the height of the deck (though the deck lids are common with the roadster and 5 window).
The bead around the fender is way different between the roadster and cabriolet and very similar between the 5 window and cabriolet. I agree with alchemy the best start would be with the 5 window panels, and a lot easier than starting with flat sheetmetal.
If you are looking for another basket case... call me.
Karl Wescott is offline   Reply With Quote
Old Today, 03:34 PM   #4
uncle buck
uncle buck's Avatar
Ha ha, I assume you are talking about the ruff one from Bill several years back. I remember when you drug that home with you.
Old Today, 05:22 PM   #5
alchemy
alchemy's Avatar
I’ve always wanted a cabriolet……
