Old Yesterday, 05:53 AM   #23
32Ford13
Default Re: Stalling at stop sign
I knew I didn’t have a vacuum leak. My stalling was cured by turning the air screw in on the carb. I did a little at a time and found a sweet spot. Had to tweek on the idle speed at the same time. Problem solved.
32Ford13 is offline   Reply With Quote
