[QUOTE=TomT/Williamsburg;2453992]When I built the wife's 40 Pickup which is in a 36 frame I used flat steel on the outside of the frame rails, made a plate for the rear spring bolts and went rearward to an adapted Chevy Suburban Class 3 hitch from the early 90s. Overkill I know for your application but where there is a will, there is a way!/QUOTE]
