Old 06-01-2026, 10:05 AM   #1
34fordy
34fordy's Avatar
Default Why is it so hard for me?
I have always struggled getting the transmission oil refilled with all of the obstructions in the way. Has anyone figured out a way to do this easily? You would think that after 65+ years laying under cars I would have figured a better way, LOL. I see that some manufacturers are putting it in plastic bags.
34fordy is online now   Reply With Quote
Old 06-01-2026, 10:10 AM   #2
35fordtn
35fordtn's Avatar
Default Re: Why is it so hard for me?
If it is a floor shift transmission, just remove the shift lever thats how I've always poured it in
Old 06-01-2026, 10:22 AM   #3
ford38v8
ford38v8's Avatar
Be careful what you wish for!
Alan
Old 06-01-2026, 10:23 AM   #4
cas3
Me too. Just be carful not to knock the li'l 1/4" pin down the hole!
Old 06-01-2026, 10:26 AM   #5
Seth Swoboda
Seth Swoboda's Avatar
The plastic bags are a big help. I've found that they make it easier.
Old 06-01-2026, 10:41 AM   #6
Fritz
Fritz's Avatar
Look up “manual fluid pump” from Amazon, any auto parts store. For a few dollars you can pump gear oil like handsoap. Easy, no mess.
Fritz is online now   Reply With Quote
Old 06-01-2026, 10:47 AM   #7
Fritz
Fritz's Avatar
Such as Performance Tool, W1139 or W1141
https://shop.advanceautoparts.com/p/...1141/7070683-P
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Old 06-01-2026, 10:52 AM   #8
34fordy
34fordy's Avatar
Thanx all ! It’s funny, getting old how I forgot that I have a hand held pump/sucker canister like a grease gun that I have used before and couldn’t remember it. It’s been a couple years! Geeeesh! This is looking serious, huh?
Old 06-01-2026, 10:54 AM   #9
Kube
Super Moderator
Kube's Avatar
Hate to tell ya, but it has a lot to do with the "65 years". I've noticed things are becoming tougher to get to and it seems most things are heavier than they used to be. Oh yeah, and remembering stuff... um, what?
Old 06-01-2026, 11:57 AM   #10
Overkill-F1
Overkill-F1's Avatar
If I remember that I have a certain item, the hard part is WHERE IS IT NOW?
Terry
Overkill-F1 is offline   Reply With Quote
Old 06-01-2026, 12:52 PM   #11
ford38v8
ford38v8's Avatar
Got out to the truck yesterday, had to go back inside to find my keys. First stages of panic when I finally found them. Out at the truck again, I no longer had my sunglasses. At last, with most of my ducks in a row, I headed off down the street in the wrong direction. That was OK, because I had to go back to get my hat anyway.
Alan
Old 06-01-2026, 01:18 PM   #12
34fordy
34fordy's Avatar
I can't help but wonder how long it will be till it is no longer a laughing matter. If it would only happen a couple times a day I would be so elated!!!!! I hate to say this but knowing that I'm not alone in the journey is comforting. LOL
Old 06-01-2026, 04:41 PM   #13
hueyhoolihan
as a matter of fact a spray bottle like Windex uses could be put to good. i've seen them with the nozzles that twist to different modes. put it on "Stream".
hueyhoolihan is offline   Reply With Quote
Old 06-01-2026, 04:43 PM   #14
hueyhoolihan
that's a good one! really had me laughing out loud. thanks!
the other day i spent a good hour hunting for my glasses, while checking for the umpteenth time in the bathroom i noticed my reflection and the glasses on my forehead. jeHEsus that's frustrating!
Old 06-01-2026, 04:50 PM   #15
deuce lover
deuce lover's Avatar
Memory is the second thing to go
Old 06-01-2026, 04:57 PM   #16
34fordy
34fordy's Avatar
It starts about 40. The spring in your legs is the first I believe. By 80 most everything below the belts has gone South. When I retired 19 years ago 6-1/2 hours of sleep was perfect. Now it's usually 9 hours, and if I sit down it might be a half hour nap, dang it.
Old 06-01-2026, 05:20 PM   #17
hueyhoolihan
thanks for reminding me.
Old 06-01-2026, 05:33 PM   #18
tubman
tubman's Avatar
At least you guys didn't make your mistakes out in public like I did (the wrong thread pitch for pan bolts in "GB SISSON"'s oil pan thread).
Then again, nobody caught it (yet), either.
Old 06-01-2026, 08:48 PM   #19
ford38v8
ford38v8's Avatar
You mean like quickie oil change outfits tend to do with SAE vs Metric when they lose the original oil pan plugs?
Alan
Old 06-01-2026, 10:21 PM   #20
oldbugger
oldbugger's Avatar
CRS or worse yet CRAFT
oldbugger is offline   Reply With Quote
