Old 05-29-2026, 06:43 PM   #1
Don S
Default Paint on car has something like tree spit
I think I must have parked under a tree and got spit on by the tree. It is not sticky like I have had before , but very fine to the feel. I have tried water and soap, windex , various polishes , alcohol ,( not the drinking type ) . The paint is in really good condition , Ditzler enamel painted nearly 50 years ago , so I don’t want to be too aggressive . Any ideas ?
Thanks. Don S
Don S is offline   Reply With Quote
Old 05-29-2026, 06:51 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Paint on car has something like tree spit
Thanks. Don S
I have used Chemical Guys Tree Sap Remover for Car with good results.
Old 05-29-2026, 08:20 PM   #3
CT Jack
CT Jack's Avatar
Regular paint thinner works great on removing tar. I would try it on a small area to if it works. It should not affect the paint just use soap and water afterwards.
CT Jack is offline   Reply With Quote
Old 05-29-2026, 08:48 PM   #4
Don S
Thanks guys , I will give you an update tomorrow .
Don S
Old 05-29-2026, 10:42 PM   #5
Don S
Had some solvent in the shop,it works. I have a lot of work ahead of me , thanks for your suggestions.
Don S
Old 05-30-2026, 08:53 AM   #6
old31
Instead of a solvent, wouldn't a clay bar be less agressive?
old31 is offline   Reply With Quote
Old 05-30-2026, 11:03 AM   #7
Don S
Old31, I have no experience with a clay bar ,and or how it would be used . I am 89 ,familiar with older products ,like varsol, solvent and, and white gas .
Don S
Old 05-30-2026, 12:11 PM   #8
Herb Concord Ca
89, glad to hear you are still driving your Model A!!
Herb Concord Ca is offline   Reply With Quote
Old 05-30-2026, 12:18 PM   #9
springerpete
springerpete's Avatar
You said you tried alcohol, was it ethanol ? That is the only one I know that works. Bill
springerpete is offline   Reply With Quote
Old 05-30-2026, 12:55 PM   #10
old31
Don, 89, good for you.
You do not have to use their spray. Any spray wax or glaze works well with a clay bar. I happen to use Meguiar's bars.
Because I have not seen your paint, I am not saying that the clay bar is better, just something to consider as it might be less abrasive on old paints
https://www.youtube.com/watch?v=g3CL04f2NAc
Old 05-30-2026, 01:43 PM   #11
ModelA29
ModelA29's Avatar
Turpentine is a highly effective solvent for tree sap because it is derived from pine resin. To use it, apply a small amount to a soft cloth, hold it against the sap to soften it, and gently wipe until dissolved. Always wash the area thoroughly with soap and water afterward.
ModelA29 is offline   Reply With Quote
Old 05-30-2026, 02:09 PM   #12
rotorwrench
rotorwrench's Avatar
Sometimes, plain mineral spirits work. It depends on the type of sap. Sap was and still is used for making some forms of paint. They are referred to as paint gums. Even boiled linseed gets hard as a rock and it comes from flax seed. It takes some of them a long time to dry but if it sets out in the hot sun it speeds up the process.
Old 05-30-2026, 04:15 PM   #13
[email protected]
Try hand sanitizer. It is the only thing I found to remove pine pitch. Isopropyl alcohol won't touch it. Hand sanitizer contains ethyl alcohol or ethanol. Also tried paint thinner and wd 40. Ethanol works on pine pitch.
Seguin2252@gmail.com is offline   Reply With Quote
Old 05-30-2026, 07:47 PM   #14
Synchro909
Synchro909's Avatar
Pure gum turpentine is made from the sap of pine trees, hence the refreshing smell. I have never found a sap it will not remove and we have some trees you guys don't know.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-31-2026, 08:14 AM   #15
chap52
chap52's Avatar
WD40. Keep enjoying and sharing your hobby. Chap
Old 05-31-2026, 02:15 PM   #16
Don S
An update on my paint issue, spent most of yesterday cleaning the paint with solvent. Not an easy project. Several steps ,cleaning the paint with warm water ,drying, then applying the solvent ,leave it on for a few minutes,the wash it off with soap and water,rinsing with clean water,wiping the area dry with a microfibre cloth. I completed this process on my car yesterday and today applied Adam’s detailer polish for a nice finish .
Thanks to everyone for your suggestions and support .
Don S
Old 05-31-2026, 04:15 PM   #17
old31
yahoo!
Old 06-01-2026, 09:30 AM   #18
Fullraceflathead
Fullraceflathead's Avatar
I'm glad to see it worked out for you and now you have a sharp looking model A!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
