Old 05-29-2026, 08:37 PM   #11
CT Jack
CT Jack's Avatar
Default Re: Dash Paint Question
Remove the dash rail, instument panel, and the steering column. To paint it correctly you will need to roughen the original paint and apply a primer. You will need to mask off the headliner, door panels and anything else that could absorb paint mist. Removing the steering column will make access a whole lot easier.
CT Jack is offline   Reply With Quote
