Old 05-23-2026, 10:23 AM   #1
34fordy
34fordy's Avatar
Default Dennis Carpenter mat
I think this new mat has been rolled up for a long time. It was in the original wrapping. Should I put it in the bathtub with very warm water to soften it up to unroll it?
34fordy is offline   Reply With Quote
Old 05-23-2026, 10:25 AM   #2
glennpm
glennpm's Avatar
Default Re: Dennis Carpenter mat
That would work but just putting it out under the sun will work as well.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 05-23-2026, 10:29 AM   #3
petehoovie
petehoovie's Avatar
Old 05-23-2026, 10:41 AM   #4
John Gibson
John Gibson's Avatar
Old rubber becomes quite brittle with age and will break easily. Letting it sit outside in the sun on a nice warm/hot day will give you a good chance of it not breaking up when you unroll it.
John Gibson is offline   Reply With Quote
Old 05-23-2026, 12:45 PM   #5
34fordy
34fordy's Avatar
I set it in the sun for an hour and carefully unrolled it. It seemed pliable so I spread it out and put some weights on the bends. Then back into the “oven” I am quite hopeful! Thanx all !
Old 05-23-2026, 01:30 PM   #6
petehoovie
petehoovie's Avatar
Old 05-23-2026, 02:00 PM   #7
glennpm
glennpm's Avatar
Hang it over a railing in the Sun contrary to the present curl..
Old 05-23-2026, 02:08 PM   #8
ford38v8
ford38v8's Avatar
You’ll want it warm from the sun while you install it also.
Alan
Old 05-26-2026, 10:30 AM   #9
alchemy
alchemy's Avatar
Should the rubber be “nourished” with anything before it’s installed? Like Armorall or something similar?
alchemy is offline   Reply With Quote
Old 05-26-2026, 11:18 AM   #10
ford38v8
ford38v8's Avatar
That seems like a good idea, but think it through and maybe experiment some. I have washed and rinsed, then a wipe-down with silicone, and very disappointed with the results. The silicone becomes blotchy, and shiny in spots. Over time, it goes back to natural, but is unsightly till then.
Alan
Old 05-26-2026, 10:19 PM   #11
nelsb01
nelsb01's Avatar
I'm going to suggest that there are better products than Armorall.
nelsb01 is offline   Reply With Quote
Old 05-27-2026, 05:14 AM   #12
Christopher Salty
You may not want to put something slippery on a floor mat.
Christopher Salty is offline   Reply With Quote
Old 05-27-2026, 06:48 AM   #13
alchemy
alchemy's Avatar
I was thinking since it’s older and been rolled up for a long time, that softening it might help it last longer.
Old 05-27-2026, 08:11 AM   #14
Kens 36
Kens 36's Avatar
Softening if good. The sun will do it better than any snake oil you put on it.
I had a Dennis Carpenter front mat for my '50 that was in the box for 7 years. Rolled it out in the sun and it laid out perfectly in an hour or so.
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 05-27-2026, 09:06 AM   #15
TJ
TJ's Avatar
Amorall would be a big "no no" in my book. It's greasy and slippery and would get on the soles of your shoes with the potential of your shoes to slip off the clutch and brake pedals.
Old 05-27-2026, 10:18 AM   #16
pistonbroke
Contrary to what they claim Arorall and all other sillicone based treatments are the WORST products to put on any ruber or vinyl.
Old 05-27-2026, 10:39 AM   #17
tubman
tubman's Avatar
A quick Google search produced this :
"To restore old, hardened rubber, use a chemical rejuvenator like MG Chemicals Rubber Renue for belts and rollers, or a penetrative conditioner like 303 Products Rubber Seal Protectant for automotive and weather seals. These products replace lost plasticizers and soften the material to restore flexibility"
Old 05-28-2026, 01:11 AM   #18
Randy in ca
Randy in ca's Avatar
Off topic, but does anybody have a recommendation for softening up pre-WW2 rubber parts? Apparently at that time, due to large shortages, a change occurred from natural rubber content to synthetic compounds being used.
Randy in ca is offline   Reply With Quote
Old 05-28-2026, 12:27 PM   #19
ford38v8
ford38v8's Avatar
Randy, I’m not aware of any rubber products of that time frame that are not synthetic by definition, but in any case, heat from the sun is effective to a moderate degree, but nothing will soften enough to prevent damage caused by the stresses of installation or removal. sunshine, extreme care and patience are your friends.
Alan
