Old 07-24-2011, 10:04 PM   #21
felix37
felix37's Avatar
Default Re: uncle gave me a 37 ford coupe
Welcome to the barn! Looks as though you have the making of a good project car.I believe fordscript may be right as there is no sharp crease on the top of the front fenders and although the rear fenders are hard to see because of the grass,they do look like 38's. If you could take a picture of the rear of the car it would be obvious by the trunk handle and rear tail lights.
felix37 is offline   Reply With Quote
Old 07-24-2011, 10:08 PM   #22
bart78
bart78's Avatar
I will try to get out there this week and take more pics. If it is a 38 will I have more options with the rear fenders? I saw somewhere that the 38 coupe can use rear fenders off a sedan. Is that right?
bart78 is offline   Reply With Quote
Old 07-24-2011, 10:13 PM   #23
felix37
felix37's Avatar
the dash board,if it has one is also a dead give away.
Old 07-24-2011, 10:16 PM   #24
bart78
bart78's Avatar
It does not have a dash. Are the hood ornament the same on a 38 as the 37?
Old 07-24-2011, 10:22 PM   #25
felix37
felix37's Avatar
believe the top part of the hood ornament on a 38 standard is identical to the 37's? my avatar has a 38 std. and my 37 front ends on it.
Old 07-24-2011, 10:26 PM   #26
59ab
Welcome to the Ford Barn. Nice solid looking coupe!
59ab is offline   Reply With Quote
Old 07-24-2011, 10:28 PM   #27
bart78
bart78's Avatar
It might be a 38. I will have to get a better look at every thing on the car. I like the 38 grill better than the 37.
Old 07-24-2011, 10:44 PM   #28
ford38v8
ford38v8's Avatar
Bart, From closer inspection of your coupe, you have a '38 Standard. I am positive.
Alan
ford38v8 is online now   Reply With Quote
Old 07-24-2011, 10:49 PM   #29
bart78
bart78's Avatar
Thats cool I like the 38 grill better and it was free witch is the best part. This will be my first car to restore this old. I have grown up around these old fords with my uncle and my grandfather. My grandfather has a giant hoard of model t's.
Old 07-24-2011, 11:04 PM   #30
ford38v8
ford38v8's Avatar
Bart, Look at Felix37's Avatar. This is what your grill will look like. Different from a '37 in that the grill bars above the headlights go all the way back to the cowl. The '38 DeLuxe has a heart-shape grill. Yours is a '38 Standard.
Alan
Old 07-25-2011, 06:09 AM   #31
coupe5w36
coupe5w36's Avatar
Welcome to the Barn. Looks like a great project, I'm looking forward to progress photos once you get started.
coupe5w36 is offline   Reply With Quote
Old 07-25-2011, 09:05 AM   #32
Planojc
Planojc's Avatar
A good source for parts and advice would be to joining a Early Ford V8 Club. You are located near the Lone Star Club in the Fort Worth, Arlington area and Stacy Brown, who is a member, has Antique Auto Supply.
Planojc is offline   Reply With Quote
Old 07-25-2011, 02:51 PM   #33
bart78
bart78's Avatar
Thanks guys I will get started on it when it cools off. The first part of july the guy that catches snakes on our place gased under the car and caught five rattle snakes. They are real bad this year and I was told by my uncle that he would not help me load it up until it gets cold.
Old 07-25-2011, 03:05 PM   #34
B-O-B
B-O-B's Avatar
Bart if you google 1938 ford or go to carnut.com you can get lots of ideas & pics.
B-O-B
B-O-B is offline   Reply With Quote
Old 07-25-2011, 03:18 PM   #35
bart78
bart78's Avatar
Thanks I will look at that. I have a prety good idea what I want to do. I want to go back with a flat head. Keep the rest prety much stock. I would like to set it a bit lower. Probably a drop front axle and I have thought about a 4 link rear suspencion. I have a 9 inch out of a old bronco that I was thinking about putting that under it. And I cant decide yet on paint.
Old 07-25-2011, 03:56 PM   #36
John T
A 38 Std hood looks similar to a 37 hood.
John T is offline   Reply With Quote
Old 07-25-2011, 05:51 PM   #37
bart78
bart78's Avatar
The hood on the 37 looks like when it rounds off it is just rounded. From pics it looks like it has a different roundnes to it on the sides.
Old 07-26-2011, 03:48 PM   #38
bart78
bart78's Avatar
Did these cars come from the factory with pin stripes on the paint. Parts of the car you can see the green paint and yellow pin stripe.
Old 07-26-2011, 07:27 PM   #39
3738
3738's Avatar
A 37 hood just rounds off, the 38 hood rounds of into a "crease or step" then rounds off again...
Regarding pin stripes... yes, ivory painted factory pinstripe on my Blue 37, but my Black 38 has stainless trim instead of a pinstripe
3738 is offline   Reply With Quote
Old 07-26-2011, 07:43 PM   #40
jack in san diego
If it has a frame under the body, look for an I.D.# on top of the frame in the area right over where the steering will mount. If you can find those numbers it will be easier to identify. Good luck and welcome to the barn. Jack
jack in san diego is offline   Reply With Quote
