Old 05-22-2026, 11:45 AM   #1
Billy 1931 Model A
Billy 1931 Model A's Avatar
Default timing gear question
Took the valve cover off. When I turn the crankshaft, the cam doesn’t turn, so the distributor doesn’t turn. It seems either the cam timing gear and/or the crankshaft timing gear is busted, right?
Also, copper gaskets or graphite?
Billy 1931 Model A is offline   Reply With Quote
Old 05-22-2026, 12:11 PM   #2
J Franklin
J Franklin's Avatar
Default Re: timing gear question
Most likely cause.
Old 05-22-2026, 12:50 PM   #3
Chuck Dempsey
Chuck Dempsey's Avatar
You can easily remove the timing gear cover, and look at what's happening. Odds are that you have a 'fiber' camshaft gear, that has stripped teeth... You can order another 'fiber' gear, or an aluminum one that will last ages. There is lots of literature on how to swap out the gear, and get it to mesh with the crankshaft gear correctly. I've no opinion of gaskets. Good Luck!
Chuck Dempsey is offline   Reply With Quote
Old 05-22-2026, 02:31 PM   #4
JayJay
Most likely the camshaft gear center is "liberated" from the toothed portion. I've never heard of a crank gear being stripped, while losing a cam gear is not at all uncommon. (FWIW, 60's-70's Volvo 4-cylinder engines were renowned for this also. Made a few bucks in college replacing timing gears on them.)
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 05-22-2026, 03:37 PM   #5
Werner
Werner's Avatar
Billy,
if the valve cover is removed, you can see the camshaft gear teeth through the opening at the front.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-22-2026, 04:11 PM   #6
Bruce of MN
Bruce of MN's Avatar
My fiber gear stripped in 2019.
Old 05-22-2026, 04:47 PM   #7
nkaminar
nkaminar's Avatar
My fiber gear stripped in 1966. I changed it out at the side of the road. I carried a new one. Now I have an aluminum gear and no longer carry a spare timing gear.
nkaminar is online now   Reply With Quote
Old 05-22-2026, 07:52 PM   #8
bobbader
If the fiber timing gear is shot …….. without the gear having spun its center, there’s a good chance the gear broke because your distributor has frozen up or is about to. If that is the case, the fiber gear became sacrificial and negated any more substantial damage to internal engine parts. This is a variable most folks don’t know about. Sooooo, whatever happened to the fiber timing gear, before you launch another one, maybe remove the distributor from the engine, be sure the shaft still turns easily by hand and is well lubricated.
bobbader is offline   Reply With Quote
Old 05-22-2026, 08:36 PM   #9
Synchro909
Synchro909's Avatar
Bob touches on something I have told others many times. Don't think that just because what was broken is repaired that all is well. Ask yourself "Why is it so?" What caused the problem - fix that and your repair is complete.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-23-2026, 09:48 AM   #10
JayJay
Truer words were never spoken, Synchro. Old school mechanic vs. current parts replacer.
JayJay
Old 05-23-2026, 10:10 AM   #11
Will N
Will N's Avatar
See Bob Bader's post right below yours. Henry knew what he was doing when he specified a fiber gear.
Will N is offline   Reply With Quote
Old 05-23-2026, 02:01 PM   #12
nkaminar
nkaminar's Avatar
Yes, the rest of the engine, including the distributor must be kept in good operating condition. I am a member of the OCD club, Often Check Distributor. I keep it oiled and happy.
