Old 05-19-2026, 12:08 PM   #1
Ld056
Default Clean Out Plugs
Does anyone know where to get the proper plugs for a Flathead Mercury V8, with the 5/8" clean out holes in the crankshaft ? I have Dorman Number 555-010 Plugs, but I don't see HOW they could possibly fit since they are slightly larger than the 5/8" hole ! I've ruined 2 plugs already. Any help appreciated. Also, I've been on line, checked with about a dozen vendors, and no one seems to habe this simple little part.
Ld056 is offline   Reply With Quote
Old 05-19-2026, 12:17 PM   #2
tubman
tubman's Avatar
Default Re: Clean Out Plugs
The traditional hot rod way has been to tap the holes and use screw-in plugs and Loctite.
Old 05-19-2026, 03:56 PM   #3
Mart
Mart's Avatar
You have to tap the plugs in with a punch. It's best to grind a suitable punch to a domed shape to drive them in. I used a smaller diameter flat ended punch and knocked a hole through the end.
Old 05-19-2026, 04:01 PM   #4
Throck Morton
You appear to have the correct plugs. 8CM-6307 cross references with your Dorman number. They are supposed to be .628 in dia. Or more likely a metric plug 16mm (.6299 )
I always installed them with a loosely fitting pin punch, or a steel bar in the center of the cup. And a 3-4 lb hammer !
If the punch fits too tight you will have a difficult time removing it as the walls of the plug collapse in from the press it.
Throck Morton is offline   Reply With Quote
Old 05-19-2026, 06:24 PM   #5
Kube
Super Moderator
Kube's Avatar
Exactly how I have done it.
Old 05-20-2026, 07:27 AM   #6
big deuce
big deuce's Avatar
Ld, what method are you using to install the plugs that's causing the failure?
big deuce is offline   Reply With Quote
Old 05-20-2026, 08:59 AM   #7
Ld056
The Dorman plugs are just made incorrectly .They are actually .625" at the closed end, and flare out to .650" at the open end. Ain't no way that oversized plug is going to fit in that hole. That's why I'm asking where to get other types. I already know how to install them, just need a quality part to start with. Thank ya'all for your responses, keep em comin !
Old 05-20-2026, 11:40 AM   #8
Karl Wolf
Karl Wolf's Avatar
I have used these plugs. It may be that the old staking is getting in the way. I used a tapered reamer to "smooth" the opening at the outside. As someone said above, drive the plug using the center of the plug, not the outside edge. Stake these in place!
Karl
Karl Wolf is offline   Reply With Quote
Old 05-21-2026, 09:43 AM   #9
Bored&Stroked
Bored&Stroked's Avatar
Once you have them in, then 'stake' the outer edge with a pointed punch - in about 3 or so places around the perimeter. A stock 49-53 oil pump can blow the plugs out if you don't stake them . . . ask me how I know such things! LOL
Old 05-21-2026, 10:15 AM   #10
tubman
tubman's Avatar
Sounds like a vote for threaded plugs.
Old 05-21-2026, 10:15 AM   #11
Bored&Stroked
Yep - that is what I have in all my racing cranks.
