After replacing the fuel gauge in my 38 pickup it registered full when it only had a couple of gallons in it. New tank and sending unit. Understand that low voltage could be the problem. Checked it out and have 6.3 volts to the gauge going in and 3.8 coming out. Does that indicate a faulty gauge or do I need to add a ground wire somewhere? Thank you for any advice.
Is your gauge compatible with your sending unit? King Seely gauge will only work accurately with a matching King Seely sending unit. They don't work on the Ohms principle.
Agree. Modern sender will never give accurate reading with an original gage.
But yours seems extreme.(needle always moving full scale) That’s not a lack-of-ground problem. Just the opposite, indicates possible short to ground. To test, remove the wire at sender and keep it from touching ground. Needle should then stay bottomed. If it does that, gauge and sender wire probably OK, problem is with the incompatible sender. |
Ok, the gauge will not work with the sending unit but I do not uunderstand why there is 6 volts going to the gauge and only 3.8 volts going out of the gauge?
#5 | |
I have never put a voltmeter on a gauge's output to the sender, but your 3.8 volts seems reasonable to me. |
Carefully check your wiring with this 40 Ford wiring diagram. https://www.fordbarn.com/forum/showt...wiring+diagram Just for the heck of it try using only a 6V dry cell to supply Voltage to your gas tank sending unit. Make sure your gauge is not grounded against your dash etc. Look here: https://www.fordbarn.com/forum/showt...ford+gas+gauge I also ran a separate ground wire from the gas tank sending unit to the frame to make sure it has a good dependable ground. Normally, the gas tank sending unit is grounded by being attached to the metal tank which rests on the frame. A separate ground wire is good insurance. Last edited by 19Fordy; 05-17-2026 at 09:21 PM. |
Location: Tasmania Australia. The land of the REAL Tasmanian Devil
Jay &19Fordu are right. However guys, If you use a 73 -10ohm sender you CAN get a reasonably accurate reading. You might have to adjust the float position a little though.
After mucking about with my original bimetal KS sender unit I finally bit the bullet and bought a 73-10 ohm unit just to see how accurate it would be. I wasn't expecting it to be as accurate as it is ! Pleasantly surprised actually. It's been in my 52 Customline for about a year or so now.
Grandfathers.... 'cause we know stuff and fix things |
Mickd: That's good news. Please keep a record of the gas tank readings at FULL, 3/4, 1/2
1/4 and 1/8 so that we can get an idea of the accuracy and how much gas is actually in the tank at those readings. Thanks. |
I was able to get my modern sender to give an accurate gauge reading near empty tank. Gauge remains very inaccurate in the upper range. Fed the sender wire thru a 9-ohm resistor just ahead of the sender. Required trial-and-error to settle on the 9 ohm. (driving till emty with a gas can in the trunk) I suspect every sender, with different float arm adjustments, would be a little different.
Thank you Jay for your helpful info.
Deleted. Not sure if what I was saying is correct, so better to not say it.
Finally got a chance to work on my truck, grounded the sending unit to the frame with a separate wire and grounded the frame that holds the gauges to the dash with a separate wire also. The gauges read full and according to the manufacturer of the sending unit that indicates a break in the wire to the unit. Ran a jumper wire from the back of the gauge to the sending unit and stiil read full. Not sure what to try, any ideas? Thanks.
#13 | |
When you ran a jumper wire to the sender, was the original sender wire disconnected at both ends? One thing that could explain needle always on F is a short to ground somewhere along the sender wire. That could also explain your low voltage reading on the gauge sender terminal, cuz voltage is dumping to ground. Last edited by JayChicago; 05-31-2026 at 12:23 PM. |
#14 |
LM44S, I'm dealing with my own Fuel Sending Unit problems and sharing what I've read. If the wire at the Sending unit isn't connected to anything, the gauge should read empty or bottom of scale. If you ground that same wire the gauge should read full or top of scale. If those two are true your gauge is good as is the wire to the Sending Unit. That test worked for me so I know I have a good gauge but can't get anywhere near an accurate measurement with the aftermarket unit.
#15 |
there are only two or three ways gasoline levels are registered. as mentioned previously, the sending unit and the gauge must be compatible. old sending units from the 40's vary the current with a rheostat in the sending unit. the gauge for those types heat a coil with a bimetallic strip attached to the arm in the gauge. modern units have nothing in common with those types. if you're using an original type of gauge it's highly unlikely a modern sending unit will work.
addressing compatibility, if indeed those are the circumstances here, would be my focus. to test your gauge, i would simply send some current through it using a battery (possibly a 1.5v battery would suffice), so as to heat it's coil and so. bend the bimetallic strip inside and the needle. but first so as to not waste time, i would check if for continuity. a working gauge should have continuity. if the gauge has no continuity, or if the sending unit has no continuity, or if the wire running from the gauge to the sending unit has no continuity or the sending unit is not grounded, the gauge should read empty. if there is a short in the circuit AFTER it leaves the gauge it could create a fire, but most probably the gauge would read full (this may have been mentioned in a previous post). |
#16 |
#17 | |
but i will suggest one might want to take another look at when timed-sensor technology was invented and became common usage in automobile gas gauge sending units. and how likely that it would be implemented in the 30's or 40's cars. as it would likely require solid state circuitry capable of measuring electro-magnetic waves involving light-speed over a distance of inches. something that is beyond the capabilities of 30's and 40's era analogue circuitry. the timed/pulse technology (common in 50's Ford sending units) that was mentioned, was dependent on a rheostat. modern sending units, AFAIK, are not. Last edited by hueyhoolihan; 06-02-2026 at 05:04 PM. |
#18 |
The current pulse system was very reliable but nothing lasts forever. The OEM gauge was a King Sealey product made to work with whatever current was allowed back from the sending unit. The indicator gauge can be tested with different dry cell batteries that have lower voltages to see if the gauge works in different levels. It would take a variable resistor to check it from full to empty on a 6-volt car battery.
There are fuel gauge interface modules available now that can be used to set low side resistance and full scale resistance to get a functional system from a rheostat type sender. Just google fuel gauge adjustment module to take a look at them. I have no idea how well they work or how long they last but they are available from different sources with different prices. Some are kind of pricey. |
#19 |
Wow ! This discussion is going on forever. Here's two pictures for you. The first one is the earlier gauges up to 55. The sender unit uses a bimetal strip which slowly bends, depending on the level of the float. The higher the float, the longer it takes to bend the strip enough to open the contact on the strip - which means that earth remains on the sender wire going back to the gauge. The result of that is, the bimetal strip in the gauge pulls the needle further towards full.
The later units were simply a rheostat with a range of 10 ohms to 73 ohms. The fuller the tank, the closer to 10 ohms to earth is presented to the sender. Once again, that would drive the gauge needle towards full (as a result of the strip bending). The later units were still 6 volts even though the vehicle is 12 volts. They used a voltage reducer (aging, using a bimetal strip "pulsing" and as a result presenting around 5 to 6 volts to the gauge units. The one single reducer powered the fuel, temperature and oil gauges. Now, I'll see if I'm clever enough to put up these two pictures I just mentioned. Trust me gentlemen. This is how it all worked ! Cheers Mick
#20 |
Whoops! Got my two pictures back to front. First one is the later unit (up mid to late 70's). The second one is the earlier set up
