Old 05-14-2026, 01:13 PM   #1
Dave in Petaluma
Dave in Petaluma's Avatar
Default A&L condensor
Can anyone tell me if the "short proof" condenser, made by A&L, is visually identifiable? I have several condensers here on the bench and most have the tabs secured with three tiny spot welds. A couple have the tab secured with solder. One with the spot weld has my own marking "A&L", but I'm not certain that it is.
Thanks in advance for any enlightenment.
Dave in Petaluma is offline   Reply With Quote
Old 05-14-2026, 01:56 PM   #2
jak
Default Re: A&L condensor
the ones made by A&L are the ones with the solder at the end.
jak is offline   Reply With Quote
Old 05-15-2026, 04:01 PM   #3
Joe K
Joe K's Avatar
March-April 2026 Restorer Magazine page 16-17 article on original versus reproduction condensers.
The distinguishing feature of first design condensers is a brass "clip" at the screw to breaker plate end of the condenser. Also originals can be seen to be "double cased". The first design didn't last long - by 8/8/27 the drawing had been revised to eliminate the brass clip. 5 subsequent revisions into 1930. The double enclosure didn't change.
Today's repop don't include the brass clip and are very obviously constructed as single case.
The article (written by electrical engineer) claims modern production is superior (i.e. more "short proof") but does not differentiate A&L as a manufacturer.
Joe K
Shudda kept the horse.
Old 05-15-2026, 06:22 PM   #4
ModelA29
ModelA29's Avatar
Is it A&L who make the ones with the 3 spot welds on the tab? I've heard they are the best repops.
ModelA29 is offline   Reply With Quote
Old 05-16-2026, 09:33 AM   #5
Flathead
Flathead's Avatar
Yes!
Flathead is offline   Reply With Quote
Old 05-16-2026, 09:35 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
Here are some tips about condensers (AKA capacitors).
Bob Bidonde
Old 05-16-2026, 01:37 PM   #7
ursus
Bob, the black lead in your illustration should connect to the (-) jack on the device.
Old 05-16-2026, 01:45 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
The original A&L condenser had the tab just soldered on.
I was using it and melted the solder— I just bent the tab to make contact and kept driving.
At the next Hershey I mentioned that it happened and was given the updated spot welded one — that was probably 30+ years ago and it’s still fine.
Old 05-16-2026, 03:36 PM   #9
Dave in Petaluma
Thanks Kurt, you finally told me what I needed to know, but now I can't distinguish between the newer A&L condensers and the NORS condensers in my collection, both of which have identical spot welds. I guess either of them will work better than the offshore brands.
Old 05-16-2026, 07:07 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
the regular ones didn’t last very long and that was before offshore ones.
I was good at changing them — could almost do it at a red light— the key is to keep the screwdriver on the screw in the hole during the removal and replacement until the screw was started.
Old 05-17-2026, 04:29 AM   #11
Bruce of MN
Bruce of MN's Avatar
I have this image of a Model A driver with a bandito-style bandoleer full of condensers.
Old 05-17-2026, 05:58 PM   #12
Flathead
Flathead's Avatar
And now we all have this image!
Old 05-18-2026, 08:58 AM   #13
David in San Antonio
David in San Antonio's Avatar
When I got the Wretched Roadster the condenser was mounted to the firewall and it worked fine. Someone suggested it got less engine heat there rather than in the distributor, but I have no proof either way.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 05-18-2026, 10:51 AM   #14
duke36
This is true from my experience, and the distance to the distributor doesn't appear to be an issue. Engine pans may help direct the air from the fan cooling the condenser in both locations.
