Old 05-10-2026, 03:59 PM   #21
Ggmac
Default Re: galled left rear axle spindle. repair? replace? buy used or aftermarket?
Stop wondering, this that and the other . Do not use any method other than what is advised on this forum . Buy rent a proper wheel / hub puller and spring spreader . Do torque your drums to 200 , if you dont want to be doing it again .
Old 05-10-2026, 04:36 PM   #22
ford38v8
ford38v8's Avatar
Unfortunately, the timing of your excellent advise is dated, as the newer generation of Fordaphiles is beginning to dominate the forums as advise from the misinformed to the uninformed. No fault of their own, mind you, only that they proudly display graduate degrees from the University of AI.
Alan
Old 05-10-2026, 08:45 PM   #23
tubman
tubman's Avatar
All I can add is that in my misguided youth, my friends and I changed a lot of early Ford spring shackles with a jack and a large "C" clamp.
Old 05-10-2026, 09:40 PM   #24
hueyhoolihan
hmmmm...i might be up for that.
hueyhoolihan is offline   Reply With Quote
Old 05-10-2026, 11:05 PM   #25
tubman
tubman's Avatar
I would advise against it, especially when you can make a serviceable spring spreader from items available at any hardware store.
Old 05-11-2026, 08:56 AM   #26
marko39
I tried that last year and things were going good until the clamp slipped off. If my head was in the way I would not be writing this today. Bought a spring spreader for the installation.
marko39 is offline   Reply With Quote
Old 05-11-2026, 11:09 AM   #27
hueyhoolihan
if i choose to do it that way, i may (and i'm serious) wear my motorcycle helmet while under there.
