Old 05-09-2026, 08:06 AM   #1
qmdv
qmdv's Avatar
Default Stromberg 97 fuel smell
I drive an open 32 roadster with no hood. Recently while driving you get an obvious gasoline smell. I have only used non ethanol gasoline. Is this an adjustment issue. I have two Stromberg 97 rebuilt by Max several years ago. And my wife has complained about a smelly garadge.
qmdv is offline   Reply With Quote
Old 05-09-2026, 09:39 AM   #2
alchemy
alchemy's Avatar
Default Re: Stromberg 97 fuel smell
Do you have a fuel pressure regulator? If not, you need one. Maybe your pump has a bit of leftover push when you turn the engine off and it’s overcoming the inlet valve?
I’m sure you’ve looked for seepage at gaskets already. Strombergs are famous for leaking past gaskets.
alchemy is offline   Reply With Quote
Old 05-09-2026, 01:54 PM   #3
38bill
38bill's Avatar
I'd probably start by checking the float levels.
38bill is offline   Reply With Quote
Old 05-09-2026, 09:00 PM   #4
paul2748
paul2748's Avatar
Check the fuel pump and related hoses/lines
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-09-2026, 09:22 PM   #5
qmdv
qmdv's Avatar
Have an electric fuel pump at the tank and a pressure regulator. With pressure gauge at fuel block. I will check the pressure more closely and get new gaskets.
Old 05-10-2026, 09:21 AM   #6
Planojc
Planojc's Avatar
Give Uncle Max a call since he built it.
Planojc is offline   Reply With Quote
Old 05-11-2026, 06:14 AM   #7
Terry,OH
Terry,OH's Avatar
The most likely spots for the 97 to leak is the bowl plugs at the bottom of the fuel float bowl.
Old 05-13-2026, 01:01 PM   #8
Ken Arms
Ken Arms's Avatar
I got tired of my 97s leaking and staining my powder coated intake, I bought a brand new 97 made by stromberg, I think they addressed some issues from the original. so far no leaks but they are pricey. Ken
Ken Arms is offline   Reply With Quote
Old 05-13-2026, 07:53 PM   #9
drgoetz
drgoetz's Avatar
I have two of the new 97's ($125 ea) and they work great.
When you get them you must disassemble them and re-establish float level and tightness. Make sure the float level is 1/16" from the top and actually shuts off the fuel. Re-tighten and check for leaks with acetone. Set idle screws at 1.5 turns out and run them in as necessary. So far no leaks and they run well.
Just my thoughts.
drgoetz is offline   Reply With Quote
Old 05-13-2026, 08:50 PM   #10
tubman
tubman's Avatar
$125? Where? I want some!
Old 05-14-2026, 05:28 AM   #11
Tim Ayers
Just my thoughts.
Are these the Chinese ones on Amazon? If not, please let us know for I'm very interested.
Old 05-15-2026, 06:07 PM   #12
Andy
Dick Smith in Phoenix used to machine the bowl screws. He mounted them in a fixture and cut a relief right next to the head. Install a O-ring and no more leaks.
Yes that Dick Smith of the Ford Museum.
Andy is offline   Reply With Quote
Old 05-15-2026, 07:15 PM   #13
69a
[QUOTE=drgoetz;2451420]I have two of the new 97's ($125 ea) and they work great.
I thought the FUEL level was 15/32" wet method.
Or 9/32" to the top of the free end of the FLOAT. Dry method.
69a is offline   Reply With Quote
Old 05-16-2026, 06:20 AM   #14
Terry,OH
Terry,OH's Avatar
Charlie Schwendler suggest the power valves may be leaking.
Old 05-16-2026, 10:07 AM   #15
petehoovie
petehoovie's Avatar
Old 05-16-2026, 07:51 PM   #16
aussie merc
aussie merc's Avatar
fuel level and fuel pressure thats the starting point strombergs a sensitive to both
aussie merc is offline   Reply With Quote
Old 05-20-2026, 04:59 PM   #17
qmdv
qmdv's Avatar
Pressure is 2 psi. I have not checked the fuel level yet. Is there a diagram showing the float level setting.
Old 05-22-2026, 02:13 AM   #18
aussie merc
if careful you can run a stromberg without the top section i engrave a mark inside the fuel bowl at 1/2" below the gasket face this allows me to see exactly what the fuel level is when running also allows to check if level rises or drops as the revs increase. Many years ago someone here was making a glass window kit that could be fitted to the EE series stromberg but havent seen the in years [pity]
Old 05-22-2026, 06:03 AM   #19
Tim Ayers
Delete
