Old 05-01-2026, 06:52 AM   #141
Ziggster
Default Re: Holley 94 Rebuild - Secondary Carb
Finally got around to installing the Edmunds intake on my C69A. Lots is small “issues”
1. Since the Edmunds intake flange face where the fuel pump/breather stand mount is higher than the Ford aluminum intake, I require the longer fuel push rod. I have the longer rod, and it’s 1” longer.
2. The Edmunds intake has 4 less mounting holes to attach it to the block. As such, I no longer mounting bolts to support the plug wire loom tube in the driver’s side.
3. For the generator to clear the first carb, I had to drop it very low. There is now less than 1/2” clearance between the bottom of the generator body, and top of the intake. This now makes my current Gates Hi-Power II V-belt (B55) too long. I got a B50 and it’s too short. Haha!
4. The port for the distributor vacuum line on the Edmunds is big in the same place, so I had to fab up a new vacuum line. The port on the Edmunds intake is located between the two carb bases.
Ziggster is offline   Reply With Quote
Old 05-01-2026, 06:54 AM   #142
Ziggster
Pics wouldn’t load the first time.
Old 05-01-2026, 10:36 AM   #143
petehoovie
petehoovie's Avatar
Old 05-01-2026, 05:37 PM   #144
Als48
Hey Ziggster, that's gonna be a really cool car when finished. Do you check out the HAMB traditional hot rods? There's a fellow from Georgia, who is building a speedster with a custom body made of fabric like an old plane. Very cool, Check it out. His thread is called Shadetree speedster or something like that. Model A powered. Keep at it, you'll get there!
Al Hook
Als48 is offline   Reply With Quote
Old 05-02-2026, 06:18 AM   #145
Ziggster
Thanks! I couldn’t have done any of it without the help and support of folks here and on the HAMB.
Yes, I’m following his build. I love his creativity and ingenuity.
Old 05-03-2026, 05:20 PM   #146
kiwi nz
kiwi nz's Avatar
I think that you may have less clearance issues with Stromberg 97 carbs as I believe the manifold was designed for use with those carbs
I have an Edmonds manifold, with future use in mind, so I thank you for explaining the issues that you have found with your manifold.
Geoff Kiwi
kiwi nz is offline   Reply With Quote
Old 05-03-2026, 06:36 PM   #147
1952henry
1952henry's Avatar
Nice job!
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-04-2026, 08:01 PM   #148
Ziggster
Thanks guys!
Had a bit of an issue with finding the correct size belt due to the lower mounting position of the generator on the Edmunds intake. Ended up going from a B55 to a B50 (Gates Hi-Power II). Had to locate the generator such the the rear hub for the bearing was below the protrusion on the carb for the screw. The bottom of the generator is just above the top surface of the intake. Fabbed up a new vacuum line for the distributor.
Old 05-04-2026, 08:05 PM   #149
petehoovie
petehoovie's Avatar
Thanks guys!
Had a bit of an issue with finding the correct size belt due to the lower mounting position of the generator on the Edmunds intake. Ended up going from a B55 to a B50 (Gates Hi-Power II). Had to locate the generator such the the rear hub for the bearing such that it was below the protrusion on the carb for the screw. The bottom of the generator is just above the top surface of the intake. Fabbed up a new vacuum line for the distributor.
Old 05-05-2026, 02:56 AM   #150
Mart
Mart's Avatar
If you have problems you could always put some risers under the carbs. Depending on clearance above, which might not be an issue in this case.
Old 05-05-2026, 05:17 AM   #151
Ziggster
That’s a good idea. Never thought of it, but I’ve never seen risers/spacers on these carbs. I have some room above the tops of the carbs. Issue would be replacing the studs for longer ones. Hoping that the configuration as it sits will work. Will know shortly. I will try both progressive and direct linkage arrangements.
