Old 05-01-2026, 08:02 PM   #1
Sparky
Sparky's Avatar
Default Best way to clean intake passages?
I’m in the middle of a valve replacement job and before I fit the new valves, I’d like to clean out the decades of black buildup in the intake passages. It’s black tarry stuff about 1/16” thick.
Is there any chemical that would easily dissolve it? If not, what’s the best method? I have a small dremel tool as well as an air-powered die grinder.
Sparky is offline   Reply With Quote
Old 05-01-2026, 08:16 PM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Best way to clean intake passages?
Is the block bare? If so, your auto machine shop can hot dip it. I believe the babbitt can be damaged by some solutions, so be careful with that.
Old 05-01-2026, 08:30 PM   #3
old ugly
old ugly's Avatar
there is some smaller diameter knotted wire wheels cone shapes. that have 1/4' shafts that are tough enough to get a lot of the stuff out. they work better once they have been used and the knotts are starting to separate and the wires will stick out sideways, but still won;t get into all the recesses. and be careful of the seats.
i can't figure how to ad a picture maybe someone could do that for you?
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 05-01-2026, 08:35 PM   #4
old ugly
old ugly's Avatar
something like this. i dug mine out to show you. once they get worn they work better. but you will still have to dig some out by hand. i use cordless drill to turn them.
old ugly
Old 05-01-2026, 10:40 PM   #5
Sparky
Sparky's Avatar
No, it's in the car.
Old 05-01-2026, 10:41 PM   #6
Sparky
Sparky's Avatar
Originally Posted by old ugly View Post
something like this
That should do it
Old 05-02-2026, 11:13 AM   #7
J Franklin
J Franklin's Avatar
I use oven cleaner spray and hose off with water.
Old 05-02-2026, 11:37 AM   #8
Sunny the Model A
Sunny the Model A's Avatar
take the intake manifold and dunk it in 5 gallon bucket with about 1-2 gallons of gasoline or kerosene and let it soak. shaking the bucket in a circular motion sort of like a washing machine will also help to break loose the crud. take it out and either spray with brake parts cleaner to strip or let it dry for a few days, then repaint it and hang it back on the car.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 05-02-2026, 12:36 PM   #9
JayJay
Me too. Small stainless steel brush like this one https://www.harborfreight.com/steel-...ush-69525.html really helps.
Dremel or die grinder with a small diameter cup brush to finish off.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
