Old 04-18-2026, 02:05 PM   #1
Albany Tom
Default 1931 Roadster door catch screw or bolt?
Can anyone tell me if the body door catches on a 1931 roadster are held on with screws into the frame, or bolts with nuts. I'd like to take one off and shim it about 1/16 or so, but I'm concerned there's a nut on the inside that will fall off and drop and I'll have to take off the panel, etc. Thanks in advance for any help.
Albany Tom is offline   Reply With Quote
Old 04-18-2026, 02:19 PM   #2
midgetracer
midgetracer's Avatar
Default Re: 1931 Roadster door catch screw or bolt?
I am quite certain that there is a tapped metal bar that is held captive by a metal cage. It has been a while since I had one apart, but I think I remember the captive strip, so you should be able to unscrew the latch and not lose the retainer. I think it can also be adjusted without losing the retainer.
midgetracer is offline   Reply With Quote
Old 04-18-2026, 02:32 PM   #3
Albany Tom
Thanks midgetracer.
Old 04-18-2026, 05:41 PM   #4
gdmn852
gdmn852's Avatar
Hello, the door latch that fastens to the inner door post , is held on with 1/4 -28 screws into a tapping plate retained by a metal”cage’ spot welded to the inside of door post . The wood for upholstery tacking some what helps to hold the tap plate retained as it has a channel to fit around it. If you should use repro latches I found that they had to be spread to align with door locking latches. If you need pictures of these areas please let me know.
gdmn852 is offline   Reply With Quote
Old 04-18-2026, 07:09 PM   #5
Albany Tom
Hi. Thanks much for responding. I don't have to replace the latches w repros. I just need to shim the existing ones out likely about 1/16" (maybe a washer) so that the door doesn't hit it. The door closes but rubs. Just loosening the screws a bit has eased the issue a bit. Pictures of the area would be a great help. I'm envisioning the plate and "cage" but a real photo would definitely be good. Again, many thanks for replying. -Tom
Old 04-18-2026, 09:53 PM   #6
Randy in ca
Randy in ca's Avatar
Here's a picture of the in place strap that holds the threaded bar.
File Type: jpg 1930 Ford Roadster - Door Latch Area #1.jpg (51.2 KB, 70 views)
Randy in ca is offline   Reply With Quote
Old 04-18-2026, 10:01 PM   #7
Albany Tom
That's so helpful, Randy. I totally get it now. Thanks everyone. Much appreciated.
Old 04-19-2026, 10:11 AM   #8
katy
katy's Avatar
You don't have to remove the latch, just loosen the fasteners holding the latch on, make the shim that you need, then notch it out from the holes to the edge, slide the shin into place and re-tighten the fasteners.
Old 04-19-2026, 02:28 PM   #9
Albany Tom
I was thinking the same thing, katy. I'm going to ensure one screw is always holding that plate and perhaps use washers with a cutout (like a donut missing a bite) for shims. Thanks for replying.
Old 04-19-2026, 06:30 PM   #10
gdmn852
gdmn852's Avatar
Hello again, if you are putting spacers between door latch and body ,as mentioned, loosen up the screws and remove one at a time. If the door gaps are uneven and you have door closing problems,check for wear on hinges,also may have to play “shim that body “ . Marco had an excellent post on that . Was some posts on Ford Barn about body shimming if needed. Roadster are somewhat flimsy if rubber shims are compressed or missing will effect door and hood alignment.
Old 04-19-2026, 06:48 PM   #11
Albany Tom
Thanks again. I appreciate the extra info.
