Old 04-18-2026, 01:01 PM   #1
coolcoupe
coolcoupe's Avatar
Default battery disconnect switch
I want to install a battery disconnect switch on my 47 car.
1. does it matter if it states 6-48 volt or 12-48 volt, will both work on 47 6volt system ?
2. what is the proper way to hook it up to a 6 volt positive ground system
3. what size cable should i use ? Thanks
coolcoupe is offline   Reply With Quote
Old 04-18-2026, 01:42 PM   #2
tubman
tubman's Avatar
Default Re: battery disconnect switch
This is assuming your car is still 6 volts, positive ground.
1. The 12 volt switch, even though it probably would work, is not even rated for your car, so why even consider it? Remember, 6 volt system require heavier components because of the greater amperage carried. Equivalent systems carry twice the amps as 12 volt systems.
2. I would put it on the negative (hot) side. That way all power to the car is cut off. Put it on the ground (positive), and everything still has power going to it.
3. 0 is OK, 00 is better.
Old 04-18-2026, 02:14 PM   #3
47topless
47topless's Avatar
The easiest way to go would be to just disconnect the battery cable from the battery.
47topless is offline   Reply With Quote
Old 04-18-2026, 02:24 PM   #4
Kube
Super Moderator
Kube's Avatar
Great advice indeed.
I would add, do NOT use one of those cheapy things that go directly on the terminal.
Old 04-18-2026, 02:33 PM   #5
coolcoupe
coolcoupe's Avatar
Hi tubman, thanks for advice on the 6volt. So one cable from the negitive post of the battery to the switch and one cable to ground on the firewall, but I have a positive ground system, I'm confused please set me straight.
Old 04-18-2026, 02:43 PM   #6
Kube
Super Moderator
Kube's Avatar
The negative side is the "hot" side on a positive ground system.
If you disconnect that side, ALL power stops right at that point.
Tubman is sharp with this sparky stuff
To be clear, you need not do anything to the ground side cable.
Old 04-18-2026, 07:27 PM   #7
paul2748
paul2748's Avatar
Some controversy on what pole to put a disconnect on. Most advise to put it on the ground side (in your case the positive if an 6V car). Without a ground, as you may know, nothing electrical will work.
That said, I have always worked with 12V negative ground cars so maybe a 6V positive ground car may be different.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-18-2026, 07:44 PM   #8
Kube
Super Moderator
Kube's Avatar
Think of your home... if wired properly, the lamp switches interrupt the "hot side". If the common side is interrupted, there can still be feed through. Much safer to interrupt the power supply.
A car is not much different, ya want to interrupt the "hot side". In the case of a stock '47 Ford, the "hot side" is the negative post.
Old 04-18-2026, 09:24 PM   #9
tubman
tubman's Avatar
And then, of course, there are electrolysis and corrosion considerations if you have power going through the car. (Probably not important if the vehicle is stored under ideal conditions.)
Old 04-18-2026, 10:28 PM   #10
cas3
I've never been a fan of those things. They quite often result in problems down the road a few years with bad connections in an un necessary gizmo. Just pull off the battery cable. If its clean as it should be, its an easy thing to deal with.
Those things are popular with the model A crowd as that wire harness is hot all the time. Your 47 has a fuse , no? Sorry, I am not familiar with post war stuff
cas3 is online now   Reply With Quote
Old 04-18-2026, 10:54 PM   #11
52flthed
I used a marine grade Cole-Hersee Heavy Duty disconnect switch. Which meant its all brass. It fit neatly in one of the existing holes of the battery support brace. Which meant it’s a short run to the solenoid and the extra cable hides nicely appearing to be the same cable.
No holes needed to drill. Nice solid feel switch. Works much better than wearing out your battery terminals. Quicker and safer too.
52flthed is offline   Reply With Quote
Old 04-18-2026, 11:14 PM   #12
tubman
tubman's Avatar
I've had one of those "on-terminal" screw knob switches on my Corvette for at least the last 20 years with zero problems. I turn it on once a year and off once a year. Each time I cycle it, I take it apart and make sure it is nice and clean with no incipient corrosion. I guess even crap works if you take care of it. I did make sure that the one I had was all brass, however.
Old 04-19-2026, 07:24 AM   #13
glennpm
glennpm's Avatar
I have a Cole Hersee 2484-16-BXbBattery master disconnect switch mounted on my ;32 seat riser. Simple to access and I always shut it off with power shutdown.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-19-2026, 08:43 AM   #14
Tim Ayers
I use the same and also located in the seat riser. Works great.
Old 04-19-2026, 09:49 AM   #15
Gene1949
Gene1949's Avatar
Less is more
Gene1949 is offline   Reply With Quote
Old 04-19-2026, 11:51 AM   #16
TJ
TJ's Avatar
I have always used the Cole-Hersee switch. Never had a problem with them. As others have said avoid the one that uses the battery post.
Old 04-19-2026, 12:19 PM   #17
30Murray
You need to remember that if either side of the battery is disconnected you have a completely dead circuit. In that case it doesn't really matter which side the switch is on. What is possibly more important is where your switch is located and if the terminals are exposed to accidentally being touched by a tool or something. If it's on the ground side, you can't short it out. If that switch on the seat riser is on the hot side, one of those terminals is always hot and can be easily shorted to the body ground. I have one located just like this but put it on the ground cable. That's much safer in my opinion.
30Murray is offline   Reply With Quote
Old 04-19-2026, 12:43 PM   #18
glennpm
glennpm's Avatar
I agree, mine is on the 12V negative ground side.
Old 04-19-2026, 01:53 PM   #19
coolcoupe
coolcoupe's Avatar
My 47 is 6volt positive ground system. So I hook one cable from the positive post (ground) to the switch and one cable from the switch to ground ( firewall)
Is that the right way.
Old 04-19-2026, 02:10 PM   #20
Don T
Don T's Avatar
This is a pic of a switch I had on my 04 Dodge pickup, the culprit (or one of them) that is guilty of being a failure. I use the truck very little and suspect I have a parasitic drain (which I cant find) as well as the normal draw these trucks take when parked. The clamping area would constantly corrode and require filing it clean and flat to keep it working. On a side note, if it was working enough to start the truck it did not mean the truck would run well. It would sputter, cough and did not like throttle inputs at all. It took me a while to figure this one out. The second pic shows part of the switch body where the bolt makes contact to close the switch; I put bluing in the contact area to indicate how actual little contact area there is in the switch, amazing the truck would start at -30C. Buy a good switch.
Don T is offline   Reply With Quote
