Old 04-07-2026, 02:45 PM   #1
Sid
Sid's Avatar
Default 1940 Ford glove compartment lid
Does anyone have a trick for removing the chrome strips on a 40 Ford Deluxe glove compartment lid without breaking the tabs?
Sid is offline   Reply With Quote
Old 04-07-2026, 05:02 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1940 Ford glove compartment lid
Nope. I will wish you the best of luck though.
If you are able, cut the clips with a small (read: tiny) cut off wheel vs. attempting to pry them off. Prying is not your friend.
Old 04-10-2026, 11:01 AM   #3
3949tl
You might be able to gently squeeze the ends of the clip together thus opening the center locking portion (hole) which will enable clip removal without stressing the tabs. This has worked for me.
3949tl is offline   Reply With Quote
Old 04-10-2026, 11:09 AM   #4
kurt v
Sometimes you can unscrew that type of clip.
kurt v is online now   Reply With Quote
Old 04-10-2026, 11:43 AM   #5
Kube
Super Moderator
Kube's Avatar
That is true. In this case, don't attempt that method. Wanna guess how I know?
Old 04-13-2026, 09:27 AM   #6
TJ
TJ's Avatar
As Kube mentions, twisting is not a good idea.
Old 04-14-2026, 09:32 AM   #7
19Fordy
19Fordy's Avatar
Take a very thin small screwdriver and grind a very sharp, thin point on it. Slide the point under the little clip tangs holding the chrome strip and gently lift up each side of the clip a little at a time.
Old 04-14-2026, 06:56 PM   #8
mcgarrett
I've used this method and it worked well. In fact, bend the tangs on the clips more than needed to help them turn loose. Use new clips when you're ready to reassemble.
Old 04-14-2026, 09:11 PM   #9
19Fordy
19Fordy's Avatar
magarrett: I also was able to reuse the original clips after I "squished" them down so the prongs griped the chrome strip stud. They pressed right on.
Old 04-15-2026, 03:40 PM   #10
mcgarrett
Yep, sometimes you can get away with using the clips again if the tangs don't fatique and break off after prying on them.
