Old 04-13-2026, 06:20 AM   #1
Brian54
Default drum/hub
Due to the fact I can't locate a decent drum/hub which are attached on 54 Fords , is there an issue with separation of the two and installing the best of each from my stash?
Brian54 is offline   Reply With Quote
Old 04-14-2026, 12:32 PM   #2
evintho
evintho's Avatar
Default Re: drum/hub
No issue. The hub should be OK and as far as the brake drum, this '68 Mustang piece is pretty much an exact replacement for a '54 drum. Many have done it.
https://www.rockauto.com/en/moreinfo...t=1744&jsn=812
evintho is offline   Reply With Quote
Old 04-14-2026, 01:33 PM   #3
Brian54
Thanks for the response ; I will sleep better tonight !
