Old 04-02-2026, 08:45 AM   #7
Ronnieroadster
Ronnieroadster's Avatar
Default Re: flathead 8BA
As written above its not that hard to remove the tube. When I did this a job myself a few years ago on two 8BA blocks I simply taped deeper into the tube so there was a good amount of threads to pull against. Then I used a slide hammer to remove the tube. Just to be sure the tube would come free heating the center casting was also done overall it was easy to do.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
