Old 03-17-2026, 02:42 PM   #1
Henry Ford IV
Default 1935 Ford Wiring at Ignition Switch
I may have the wires on the ignition switch mixed up. One is for the coil, the other, the battery. Can someone please tell me which wire goes to the "high and outside" terminal? It is the higher of the two terminals and is toward the outside of the car. I cannot see Batt or Coil marked anywhere on this box.
Henry Ford IV is offline   Reply With Quote
Old 03-17-2026, 09:16 PM   #2
Brian
Brian's Avatar
Default Re: 1935 Ford Wiring at Ignition Switch
I honestly don't think it matters; it's only an on/off switch
Old 03-17-2026, 11:11 PM   #3
FlatheadTed
FlatheadTed's Avatar
as Brian says it can be either one
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-18-2026, 07:21 AM   #4
Terry,OH
Terry,OH's Avatar
Yes it does not matter, go with the length of the wire for a neat appearance.
Old 03-18-2026, 08:45 AM   #5
Henry Ford IV
Yeah, I see that, and even though one goes to the resistor and the other to the fuse, it doesn't matter; they are interchangeable.
