Old 03-13-2026, 04:07 PM   #1
aussie merc
aussie merc's Avatar
Default fan clearance
looking for factory fan to radiator core clearance as have had a custom rad made that deleted the 4th row of cores but increased the surface by 35% vehicle is 39 mercury also thought about fitting fan ring or making a shroud [not an easy option due to crank fan and lower cooling pipes ] not a lot of clearance
aussie merc is offline   Reply With Quote
Old 03-13-2026, 05:19 PM   #2
19Fordy
19Fordy's Avatar
Default Re: fan clearance
Photos please.
Old 03-13-2026, 10:55 PM   #3
ford38v8
ford38v8's Avatar
Aussie, I don’t understand how 3 rows can have 35% more surface than 4 rows. Please explain?
Fan proximity to radiator ( without a shroud) should be no more than an inch. With a shroud, the important relationship is fan to shroud, the trailing edge flush with the shroud. The crank mount fan was not one of Ford’s better ideas, but a shroud can prove to be the best use of your new radiator.
Alan
ford38v8 is online now   Reply With Quote
Old 03-14-2026, 03:26 AM   #4
aussie merc
radiator is taller and wider hence the increase in the frontal area also buy the time that the airflow finds its way back to the forth row its already absorbed about as much heat as it can so the forth row does very little also the tubes are 3/4 against the standard 1/2 so the actual capable coolant flow is higher add to that 14 fin per inch against 8 fin per inch so technically and on paper you can cool a big block with it just trying to optimize what i have as we suffer with a normal heat range of neg5C to 40+C winter/summer
Old 03-14-2026, 04:10 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
From everything I've ever heard, the closer to the radiator core, the better. I usually try to shoot for 1/4" or so.
Old 03-14-2026, 04:50 PM   #6
rotorwrench
rotorwrench's Avatar
Air flows pretty fast through the radiator at speed. Its depends on fin count too. Those crank mounted fans turn slower but have more blade surface area than belt drives. I've not heard too many complaints from 39 deluxe or 40 Ford owners about problems with overheating as long as the cooling system is clear. I don't know a lot of 39 or 40 Merc owners so I don't know about them. They should be about the same as post war cars as far as reliability.
Old 03-14-2026, 04:59 PM   #7
aussie merc
cooling systems seem to be ok in cooler climates as owners in tasmania dont report any problems it only seem to be where you get the wider swings between summer and winter that this problem raises it head
Old 03-14-2026, 05:42 PM   #8
aussie merc
by the way the factory fans may be six blade but due to the fact they are duel diameter [ factory fix to get rid of fan drone ]they struggle to make that big a differance with a shroud or ring as only 3 blades are close enough to the opening to have any effect
