Old 03-13-2026, 11:56 AM   #1
Mike1291
Mike1291's Avatar
Default Stud Fitment in Cast Iron Drums
I had new cast iron drums put on my original hubs recently by a machine shop. I noticed that some of my studs were loose when I was taking off a wheel and it appears that all four drum/hubs were affected with loose studs. It appears that the stud shoulder is not all the way through the drum as I see in other reference pictures.
I have a friend with a press and we tried to see if they'd go in any farther but no luck.
Is it possible that the wrong type of studs were used (ones for original stamped steel drums) or that the stud hole in the drums are not correct?
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 03-13-2026, 12:17 PM   #2
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Default Re: Stud Fitment in Cast Iron Drums
The studs should have an indexing on it's shoulder that fits in a notch in the drum.
dansluck is offline   Reply With Quote
Old 03-13-2026, 01:01 PM   #3
Mike1291
Mike1291's Avatar
Here's a picture of a front stud - the gap near the face of the drum opens and closes when the stud is moved
File Type: jpg PXL_20260313_175824282.MACRO_FOCUS~2.jpg (34.5 KB, 31 views)
Old 03-13-2026, 02:18 PM   #4
Sport King Eric
Sport King Eric's Avatar
I found it takes a pretty powerful press ( I did mine a second time with a 30 ton) to set these lugs. I found out the hard way if the lug stud wasn't crushed enough the stud would wiggle. I originally tried to set the studs with a 12 ton and the studs were loose. I would check the indexing (make sure the notch on the inside is clocked correct ) and then try to set them again..
Sport King Eric is offline   Reply With Quote
Old 03-13-2026, 02:48 PM   #5
Mike1291
Mike1291's Avatar
Right, he has a 100 ton industrial press that he uses on forklift equipment. 27 tons is what we used and the studs are indexed correctly. As a matter of fact the only reason they haven't spun yet is because of the index
Old 03-13-2026, 03:19 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
were the old studs drilled or had the swedge cut off before they were pressed out?
perhaps they were just pressed out and the holes got enlarged.
When I did mine on a 40 ton press it showed 23 tons to fully set them.
Old 03-13-2026, 04:42 PM   #7
nkaminar
nkaminar's Avatar
I suggest you send all 4 drums/hubs to Randy Gross to have him redo them. I have never seen or heard a complaint about his workmanship.
Old 03-13-2026, 07:06 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
This is true and he is a heck of a nice guy.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-14-2026, 06:38 AM   #9
Randall
Randall's Avatar
https://youtu.be/s1pLdra4M0o?si=6aszhUyGAUkbz1GG
Randall is offline   Reply With Quote
Old 03-14-2026, 09:57 AM   #10
Richard Knight
Did you use the proper seeding tool. The studs should be absolutely tight. I would re swedged them to see if they tighten up.
Richard Knight is offline   Reply With Quote
Old 03-14-2026, 09:58 AM   #11
Richard Knight
Spell check! Swedging!
Old 03-14-2026, 12:20 PM   #12
rotorwrench
rotorwrench's Avatar
I don't know the way back word origin of swage, swaged, or swaging but AI has it as old French "souage". The French made the Statue of Liberty with the repousse process so there is a relationship between those two words.
Making the original design lug studs longer may have a problematic issue with the swaging process but it also depends on the type of steel and processes it took to form it. Some may be better than others.
Old 03-14-2026, 12:56 PM   #13
Benson
Old 03-14-2026, 02:06 PM   #14
Mike1291
Mike1291's Avatar
Perhaps this finding could be useful.
I've taken screenshots of two different jobs of people swaging studs, and I compared them to mine. Notice how the two reference images have completely flat shoulder areas right up to the threads. If you look at mine it appears that only part of the shoulder was caught and the rest was not pressed, and left a ridge. I have read that there are reproduction tools that are oversized that won't compress the whole shoulder of the stud.
Yes I've talked to Randy Gross before, nice guy. Shipping both ways would total ~$300 which is really not ideal.
I have yet another friend with the proper swaging tool (come to find out today), he just doesn't have the alignment fixture to hold the tool
File Type: jpg PXL_20260313_175824282.MACRO_FOCUS~4.jpg (60.4 KB, 14 views)
