Massive amounts of oily steam from the exhaust...suddenly running poorly.
Looks like I get my first Model A head gasket lesson! It isn't leaking externally, no water in the oil. She just started pumping steam and I'm getting a bunch of carbon/water on the floor out of the exhaust (I think that's the worst stuff I've ever had to clean off the floor...carbon black is almost as bad as Prussian Blue...). I guess I'll make up a list of parts and get an order going. I've searched the forum for tips, techniques, gasket recommendations (509C w/copper spray). Watched a couple of videos. Last time I installed a head gasket was when I was 13...on a 289 Chevy. ![]() Of course, this will be a great time to heli-coil those distributor locking screw threads. Probably get a new set of head studs and nuts. I have a basic gasket set (no head gasket). Might as well replace the old radiator hoses while I'm at it.
'31 Ford Deluxe Coupe "The Green Hornet" |
Trapdoor2, this video from Paul Shinn should be of help to you.
https://youtu.be/Mh3VZ6iQSGU?si=s5Iw0IVZ_AWkmjw5
--------------------------------------- 1929 Model A Tudor - "Darla" '29 Model A: Old enough to start with a crank, young enough to steal the show! "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
Hello, at least you won’t have to reset valves on a Model A , drain water. , remove hose , maybe the water pump, some times the head and block have gained a great affection to each other, I have made an adapter to fit the spark plug and pressurized the head to release from block , if you have problems with that. Good luck.
Follow what Paul does in his video, take out the spark plugs, loosen the head nuts, shove some nylon rope (Lowes/Home Depot) into the front and rear spark plug hole till you can shove no more, bump over the starter gently and the head should pop up. The video shows Paul doing just that.
#5 | |
I'm still in the testing mode. I checked the torque on as many head nuts as I could get to...some took a few degrees before they got up to 55in/lbs. I need a distributor torque wrench/adapter. I may have caused the problem when working on the distributor...I had to remove #8 and reinstall several times to get the cable clamp off for distributor removal/installation. I'll see when I get the head off. It will take a week or two for all the parts to arrive. I figure I might as well rehab everything associated with the head (water pump, etc.).
https://www.amazon.com/dp/B000I1PLUU...RCKC9Q25G&th=1 |
#7 | |
#8 | |
Now that I think about it, I remember getting 5 full sets of crow foot wrenches for installing fuel tubing into Tomahawk Cruise Missiles. We only needed a couple of sizes but the stupid supervisor on 2nd shift turned in the request...and got the full sets from Snap-on. I guess it wasn't his money!
#9 | |
Looks like they're no longer made. Ebay has a scabby, rusty one. I might keep an eye out...
Here is the adapter for the torque wrench to get around the distributor.
https://modelastore.com/index.php?ro...&category_id=0
My home made offset wrench. I needed it for the manifold nuts with an intake manifold for a Weber down draft carburetor. The square tubing transfers the torque just fine.
#12 | |
#13 |
Since it still runs. Drain the water, back the head nuts off a few turns and start the car. That will pop the cylinder head loose.
#14 |
Not sure if you're going this route but if you don't have a high compression head, this would be a good time to consider one. Huge improvement in the giddy-up!
Steve, Proud owner of 28 Fordor, been in family since 63 30 Tudor 31 S/W Town Sedan Skyline Chapter MAFCA, MARC |
#15 | |
![]() Here at the beach, the only hills are overpasses. There's very little actual need for extra oomph.
#16 | |
#17 |
Yeah, no. You can find nice ones for the price of that rusty one on E-Bay. I bought the basically un-used one in the picture for $40.
#18 |
LOL!
![]() Dad's '29 roadster pickup had a 322 nailhead Buick in it. Before the Buick, it had a flathead V8 (Mercury, IIRC). I wish I could find the picture of it with the flatty, it was beautiful. The Buick had a full set of lakes pipes. If we went out of the city, I could sometimes talk him into pulling the plugs out of the pipes. OMG loud!
#19 |
Do you think he should maybe check his block for flat spots or might mill the head since he’s got it removed?
#20 |
