Old 03-08-2026, 05:56 PM   #12
34 fordor owner
34 fordor owner's Avatar
Default Re: Holley 94 Carb on 34 engine
Originally Posted by 34 fordor owner View Post
Okay this may be the case of having an improper mounting base. Would this extra hole be on the intake manifold itself or would it be on the bottom of the carb? I don’t have any extra ports on the carb itself. I will need to pull the carb and check and probably rebuild it again as well. I dropped the throttle screw back some today and the idle screw on a turn or 1/2 turn out from the engine dying. There are small pops coming from the exhaust every once in a while, like unburnt gas. After I take a look into the carb this may sort itself out.
https://youtu.be/hHCgazDEQ8c?si=WeEbopRxh4G746iD
Okay I looked up some pictures and I see the extra small hole that has been mentioned above. If I have a proper gasket that would not include that hole, like a stromberg gasket, it could solve the issue if that hole is there?
34 fordor owner is offline   Reply With Quote
