Attached is an image from the 50-813152 Ford Engineering Drawing from 1935 showing the part you are asking about. It's straight except for a short section on the bottom. Hopefully you can figure it out as it's a bit dark and is just a small section of a very large drawing.
This support has anti-rattle material between it and the back of the cab and so does the roof support rib(s). I used Dyna-Mat to insulate my cab and slid this material into the gaps and it works just fine.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
