IS THERE ANY REASON WHY AN ORIGINAL 1939 TO 1948 FORD GENERATOR CAN NOT BE USED WITH A 12 VOLT REGULATOR AND 12 VOLT BATTERY ?
40larry |
without going into the details, i'll say that as the question is worded, the answer "NO" there is no reason why you can't. but "yes" there are plenty of reasons why you shouldn't and is unlikely to work well or for long, if at all.
the details are contained in many forums on the subject of the 6v to 12v conversion process on Fords and many pre-1950's cars from all over the world. they can be found by googling. they can also be found using the search tool on this site. good luck.
Steve Blancard in VA can convert generators to 12V. It’s kinda labor intensive though, the field coils are not available as I recall so he has to make em by hand.
Is the question - can I use a 6 volt generator in combination with a 12 volt battery and regulator?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
The armatures can take it but the field windings have larger gauge magnet wire and fewer turns. The standard 2-brush 6-volt types were generally only 30 to 35 amps capable. I'm not sure what a 12-volt conversion would be capable of. A person should use field coils that match the regulator that is needed if possible. The regulator controls it so a 1956 or later generator set up could be used to emulate the design characteristics for an older type.
...interesting question. why not give it a try and let us know how it goes? i'd be interested in hearing about it. i always find empirical evidence compelling.
You might check with this fellow.
https://www.fordbarn.com/forum/showthread.php?t=355910 Generators are somewhat limited compared to alternators but Ford used them successfully from 1956 to 1964 to do the job for 12-volt systems. Alternators are still the best systems to this day. |
I have have 12v converted generators in stock or can convert yours. Glad to help if interested.
Restored Ford 6 & 12 volt generators |
#9 | |
Regards, Kevin. |
