Old 03-01-2026, 09:53 AM   #1
blownford
Default Coil Tester
I picked this up off eBay. It was listed as a Model T coil tester however I don't think it is.
Basically it's just a wood box with a KW coil mounted inside.
On the outside there are 2 power wires with alligator clips, a spark plug cable and an on-off switch.
The coil is screwed to the outer box and the 3 connections are soldered to the coil. Would be difficult to put switch to a different coil There are remnants of a label on the box but not legible.
Any Idea what this was used for?
blownford is offline   Reply With Quote
Old 03-01-2026, 09:58 AM   #2
blownford
Default Re: Coil Tester
Messed up Here's pics
Old 03-01-2026, 10:39 AM   #3
stevests
stevests's Avatar
WAG - electric fence power source ?
stevests is offline   Reply With Quote
Old 03-01-2026, 11:30 AM   #4
blownford
Well that could be, I also understand the coils were used on hit/miss engines so maybe something to do with that.
One thing for sure, because its been protected inside the box, the coil looks brand new.
Old 03-01-2026, 02:09 PM   #5
rotorwrench
rotorwrench's Avatar
It could be used to test spark plugs or perhaps a timer's circuits.
Old 03-11-2026, 02:18 PM   #6
olivia_49
Seems like a simple DIY spark tester, not a real Model T tester, just a coil in a box with clips and a switch to see if it fires.
olivia_49 is offline   Reply With Quote
Old 03-12-2026, 12:19 PM   #7
normren
Its a homemade spark plug / ignition coil tester, not specifically a Model T coil tester.
normren is offline   Reply With Quote
