Old 02-23-2026, 12:35 PM   #1
oldford
Default What type of spray glue to use on panel boards
On my friends 31 we are going to install upholstery panel boards that fit around the quarters and back window. We have the original boards and will be using new material from Classique. I would like to find a spray contact cement that has a very fine spray and will not bleed through material. Some of these spray cans spray out big globs of glue and I think that will cause hills of glue so would like to find a fine spray. What have you guys used and did it spray OK. Thanks
oldford is offline   Reply With Quote
Old 02-23-2026, 01:19 PM   #2
JayJay
Default Re: What type of spray glue to use on panel boards
I use 3M Super 77 or 3M High Strength 90, whichever I happen to have on hand. The secret is to clean off the tip with acetone frequently, otherwise it gets gooed up (technical term) and the spray gets gloppy (another technical term).
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 02-23-2026, 01:52 PM   #3
Chuck Dempsey
Chuck Dempsey's Avatar
Can concur....
Chuck Dempsey is offline   Reply With Quote
Old 02-23-2026, 08:13 PM   #4
oldford
Thanks, I will try one of those.
Old 02-24-2026, 04:32 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Just my opinion, but from personal experiences I think you will regret using either of those. If you have ever looked at a Model-A Trim Panel such as the Door or Kick panel and seen delamination or bubbles under the material, it is almost a sure-fire bet that '77' was used. IMO it will be much better if you use Weldwood's Landau & Trim Contact Adhesive. It can be brushed on, -or sprayed
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-24-2026, 08:55 AM   #6
desotoguy
The Weldwood adhesive is available in a spray can. This is really good adhesive made for upholstery work. one source: https://www.ebay.com/itm/12766262477...tion=view_item
desotoguy is offline   Reply With Quote
Old 02-24-2026, 09:59 AM   #7
Fullraceflathead
Fullraceflathead's Avatar
I agree with terry's recommendations and his vast experience 100%!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-24-2026, 11:31 AM   #8
Tacoma Bob
Tacoma Bob's Avatar
Totally agree. Been using Weldwood since Moses left Egypt in a Model "A". It's the real deal.
Tacoma Bob is offline   Reply With Quote
Old 02-25-2026, 10:57 AM   #9
rotorwrench
rotorwrench's Avatar
I don't use any spray can contact adhesives. Most are crap. The nozzle is not good for adhesives and the stuff is too thin to work well. The Weldwood is good stuff. I either use a brush or a cheap syphon type spray gun with no thinning. I don't do upholstery for a living so I generally clean the gun between jobs. If a person uses the stuff regularly then gun cleaning isn't an issue. Clean the nozzle if it gets crusty and it's good to go.
