Old 02-22-2026, 05:57 PM   #1
jonahboo
jonahboo's Avatar
Default What is a compatible transmission for 1953 F100
Well, a big thank you to you guys for your insights
After i pulled the side cover i discovered a chipped gear and bit of metal trapped between the gears below it
so, i'd like to see if i can find another trans to swap in
the truck is a '53 Panel - attached are photos
what years will work?
thank you again guys
jonahboo is offline   Reply With Quote
