Old 02-20-2026, 03:00 PM   #21
tubman
tubman's Avatar
Default Re: Porta walls
We may have revived a "lost art" here!
Old 02-20-2026, 04:42 PM   #22
sidevalve8ba
sidevalve8ba's Avatar
I was checking out the ads on AMAZON for these. Holy Cow! a hundred and thirty some bucks for a set! I'll bet we didn't pay more than $5 a pop for them probably at Western Auto or some such place. I must be getting old or something!
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 02-20-2026, 06:24 PM   #23
TJ
TJ's Avatar
Yep, Western Auto and JC Whitney. Here on the "left" coast I think they were about $10 for a set of four.
Old 02-20-2026, 06:26 PM   #24
Joe B.
Joe B.'s Avatar
I think someone told me portawalls don't work well on radials due to the sidewall flex difference.
thread killer
Joe B. is offline   Reply With Quote
Old 02-20-2026, 09:31 PM   #25
tubman
tubman's Avatar
Could be that by the time radials became popular, the "secret" of installing them correctly had already been lost. We'll probably never know.
Old 02-21-2026, 08:15 PM   #26
Sid
Sid's Avatar
Is that the same 40 Ford you had in the 70's that you posted earlier?
Sid is offline   Reply With Quote
Old 02-22-2026, 11:05 AM   #27
19Fordy
19Fordy's Avatar
ANSWER: Yes, it's the same 40 Ford. I bought it in 1963 for $400 and am lucky enough to still have it. Was originally Folkstone Gray.
Old 02-22-2026, 02:31 PM   #28
petehoovie
petehoovie's Avatar
Old 02-22-2026, 03:03 PM   #29
Sid
Sid's Avatar
Good for you I see you have a 8BA in it. What did you do about the anti chatter rods? I am running a 59 engine in mine. Runs well but the rear main leaks. I have a good 8BA engine sitting in my shop I considered using. I would probably go with the earlier cam distributor and heads.
Old 02-22-2026, 03:21 PM   #30
Anteek29
Anteek29's Avatar
When I was in high school I wanted whitewall tires, so I thought about painting the blackwalls already on my car. But before I did I tried my 'technique' on the spare. I used oil base white house paint and soon discovered the whitewall became a tanwall with cracks! Ha-Ha.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 02-22-2026, 03:52 PM   #31
Sid
Sid's Avatar
Anteek29.. I like your 55. I miss mine. I sold mine so I could buy my 40 in 2018.
Old 02-22-2026, 06:02 PM   #32
petehoovie
petehoovie's Avatar
Old 02-22-2026, 07:23 PM   #33
19Fordy
19Fordy's Avatar
Sid, I welded brackets to the 1950 Merc bellhousing and modified the OEM anti-chatter rods so they fit. Installing an 8BA in a 40 is not just a simple drop in and go. Lots of small details required. Read more here:
https://www.jalopyjournal.com/forum/...coupe.1060915/
and here:
https://www.fordbarn.com/forum/showthread.php?t=224274
To be HONEST , it would be a lot easier to rebuild your 59 engine rather than install an 8BA. You won't notice any big performance difference and you won't have the headaches of making tons of modifications and changes that arise.
