I got a 'std' Henry luggage bar and I know they can be hard to find and expensive.
I had flenges ( thick ) from a spare tire bar and idea was make one, as I notice price over 1K for a std. This one was not any cheaper, but here in Sweden. It was straight and I notice the edges in the luggage flenges indicated a std Henry, and it had several layes of paint. After blastred it I notice the weld feel not Henry, but rust show it is not welded in recent time, but it look odd. Ideas ? Last edited by 3W Hank; 02-15-2026 at 02:00 PM. |
#2 | |
Proto type or very early assemblies are often rough. Newc
Provided the brackets are correctly positioned & the rack & hardware fit it appears a bit of filler& high build primer would make it serviceable.
Yes as I payed rather high buck and its a std bar I will not do much more than filler and paint. My car will be nice car ( no patina ) but idea is based on Henry parts and old speedparts but as it’s a hotrod it will has new parts made and some old high modify.
But when it comes to a part like this they never made own made bars back then ( my guess ) as if so I could made one cheap and supernice and also chrome it. So it make no sense try make this nice. Its a cool bar anyway. No one really cares so it’s more a own inhead issue. |
Phil |
Intresting, as I seen way better welds on others, one idea this was a very early made one.
I guess this was optional Ford might used many different factorys. Maybe the Canada factory was not hold the same works (?) My is ugly but I will do as one said, some fine grind and filler, and its Ok. |
What are the two bronze pieces?
