Old 02-21-2026, 02:47 PM   #1
Terry Burtz, Calif
Default Re: Water Pump Question
Originally Posted by rotorwrench View Post
I tend to look for a parts source that gives me more choice in available products for stuff like this. I also have sources that I trust more just due to my own personal experience. The water pump parts available are all over the place in quality and reliability. There are other types of front bearing to include the original Hyatt type roller with liner and the more modern ball bearing type which some folks choose for being heavy duty at least in theory. I still use the Hyatt type front bearing since it has a longer history of relatively reliable service. The bushing with the rubber seal still has a packing in case the seal craps out so a person can limp a while before going back into the pump. I do use the adjustable thrust sleeve on the front to prevent the shaft from futher wearing on the stub inside the cylinder head. It seams to keep the shaft in check pretty well.
So far, no source offers a carbon face seal on the wet side to eliminate the packing. This would be the most reliable type but it just hasn't happened yet. Maybe some day!
A new water pump, which looks original and features a Carbon/Ceramic face seal, will soon be available. I will post more details in the thread titled "I need a job".
The new water pump uses 3 deep groove ball bearings that are sealed for life, and the same face seal that is used in Ford 2.3 (140), 2.5 (153), 3.0 (183), 3.3 (200), 3.8 (231), 4.1 (250), 4.2 (255), 5.0(302), 5.8 (351), 6.6 (400), and 7.5 (460) engines. This face seal is also used in water pumps for American Motors, General Motors, and Chrysler engines.
Terry Burtz, Calif is offline   Reply With Quote
Old 02-21-2026, 05:22 PM   #2
rotorwrench
rotorwrench's Avatar
Now we're talking. That should be as close to "leakless" as it gets. They all crap out eventually.
Old 02-21-2026, 05:33 PM   #3
Synchro909
Synchro909's Avatar
That sounds VERY like what I have done to a couple of my water pumps. I've run a carbon seal for at least 10-12 years and even considered sending some to the US.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
