Old 02-14-2026, 11:40 AM   #21
Phil Brown
Phil Brown's Avatar
Default Re: Lubrication Question
Originally Posted by 1928 Sport Coupe View Post
Be careful with these parts. I purchased one awhile back.
The Model A valve cover filter adapter is made to use an FL-1A Motorcraft filter or equivalent, the nipple is 3/4"-16. The 90 degree adapter input end screws onto the 3/4"-16 nipple fine but the output end of this 90 degree adapters is supplied with a 22x1.5mm nipple and uses a FL-820-S Motorcraft oil filter or equivalent. That would have been ok, except the output nipple will not screw into the 90 degree housing, it will only screw in about 1/4 of a turn before it gets tight. Either the female thread is out of specification or the nipple is. The supplied nipple will screw into the FL-820-S filter ok.
Ideally I thought the output should be the same as the valve cover adapter is. Then you could use the Motorcraft FL-1A or FL-400-S or equivalent filters. I use FL-820-S filters on two of my other vehicles so I thought that would be OK.
I would bet that the output side is also 3/4-16 to use a FL-1A type filter and you got the wrong nipple
Phil Brown is offline   Reply With Quote
Old 02-15-2026, 12:15 AM   #22
1928 Sport Coupe
1928 Sport Coupe's Avatar
The threaded nipple fits an FL-820-S filter, It is too large to fit the FL-1A filter
(I tried both filters) The nipple will not fit the 90 degree adapter it came with. I tried both ends. The filter pictured is a Purolator equivalent to the FL-820-S.
Besides I think the adapter would hold the filter too close to the block and interfere with the oil drain back tube.
1928 Sport Coupe is offline   Reply With Quote
Old 02-15-2026, 10:43 AM   #23
bobv
bobv's Avatar
I use Napa 7502 filter
bobv is offline   Reply With Quote
Old 02-15-2026, 12:02 PM   #24
old ugly
old ugly's Avatar
Randall. (https://youtu.be/9YXjaxxC7rE?si=3hjP2ezEiBit84gL) that is a good test video.
i am surprised that the gallery baffle at #1 cyl. was modified by ford in 1928. it was raised by about 5/16" to the height of the lifter boss, aswell the timing housing opening baffle was lowered.
it doesn't seam like a lot of oil going into the rear sections of the gallery.
i suppose that on the first blocks too much oil was directed rearward because the pump delivers lots of oil.
i don't know but maybe not enough lube to the camgears?
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
