Old 02-10-2026, 11:58 AM   #4
glennpm
glennpm's Avatar
Default Re: 1950 Ford Custom Brake Master Cylinder
Originally Posted by DNLs1930 View Post
Thanks for the link to a really good video on the operation.
So the return bypass fluid would increase the pressure in the reservoir but the cap it is vented so it can't build up; makes sense.
I will keep checking the fluid level and see what happens with the new seal on the cap...
Yes that's correct the cap vent prevents pressure buildup from the pressurized brake fluid squirts out the bypass hole.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
