Old 02-09-2026, 06:19 PM   #1
hueyhoolihan
Default how to fix or replace bend rear radius arm.
i discovered that i've got a bent rear radius rod. they consist of two 1 1/2" tubes that run from an anchor point on either side of the middle of the torque tube to each rear axle at the brake backing plate. AFAIK it centers the rear axle to the frame and permits vertical and a bit of twisting rear axle movement similar to a torsion bar.
it needs to be fixed as i think it may be the root cause of my vague steering issue. at first it thought it was the steering box, then the king pins, but now that i've found the bent radius rod, i'm suspecting that's the problem.
i've actually had one end of it off when replacing the left rear brake backing plate, which led me to discover that it was bent. just finding out what the darn things are called proved quite time-consuming!
anyway...any information as to how to go about fixing it would be welcome, as usual. thanks.
hueyhoolihan is online now   Reply With Quote
Old 02-09-2026, 06:30 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: how to fix or replace bend rear radius arm.
Large press with patience. Sadly, just last week I tossed two beautiful rods away.
Kube is online now   Reply With Quote
Old 02-09-2026, 06:52 PM   #3
ford38v8
ford38v8's Avatar
Huey, a bent radius rod will affect tracking, the obvious result being faster tire wear, the less obvious being an increased effort to keep driving a straight line forward. This last indication negligible on a crowned road if the left rear is bent (rather than the right rear), meaning a built-in tendency to pull back to the left (crown). This is my logic, not backed with documentation.
Alan
Old 02-09-2026, 06:53 PM   #4
Tim Ayers
I would also add using heat from an oxygen/acetylene torch will help you get the metal to go the way you want it to as well. Cold bending can lead to over correcting and making the issue worse. Just my two cents.
If you aren't confident using a press or heat, radius rods are still plentiful and you should be able to source a replacement easily.
Old 02-09-2026, 07:16 PM   #5
hueyhoolihan
don't confirm this BTW, but i'll just comfort myself with the thought that they were both for the right side. how's that?
Old 02-09-2026, 07:23 PM   #6
hueyhoolihan
i probably should have mentioned that the steering is not just vague, it's downright harrowing over 40MPH. the steering doesn't appear to be any major slack and the front wheels don't appear to have excessive play. the car just wants to wander. so much so that i haven't had it over 50MPH yet. :0
anyway, what i'm taking from the responses is that if i can get it removed (and like i said i know how to remove it from the axle end) it can be straigtened. which is good news. and that i might be able to purchase a used one.
anybody know if anyone manufactures a reproduction?
Old 02-09-2026, 08:01 PM   #7
Kube
Super Moderator
Kube's Avatar
Pit free, perfectly straight, left and right.
Tried to give them away for the cost of shipping. One guy told me I should ship them to him for free as well.
I don't need to make money, but lose?
Old 02-09-2026, 08:02 PM   #8
Kube
Super Moderator
Kube's Avatar
anybody know if anyone manufactures a reproduction?[/QUOTE]
Never...
Old 02-09-2026, 08:08 PM   #9
KiWinUS
KiWinUS's Avatar
These are stamped/wrapped sheet metal and in my opinion a challenge to straighten correctly. It can be done but honestly you would be better to find a replacement.
Old 02-09-2026, 08:10 PM   #10
Tim Brown
Tim Brown's Avatar
Left Side for a 1941? Is that what youre looking for? I probably have one...
Shoot me an approximate measurement and I can check.
Tim Brown is offline   Reply With Quote
Old 02-09-2026, 08:53 PM   #11
Gene1949
Gene1949's Avatar
Just my $0.02 here. If it’s wandering, you have a castor and/or a toe out issue. A bent radius rod would be a constant pull in one direction or the other.
Gene1949 is offline   Reply With Quote
Old 02-09-2026, 10:02 PM   #12
hueyhoolihan
thanks, i'll keep that i mind.
but there's no doubt that the rod is bent upwards at least half an inch. so it's been shortened a bit, but it, i agree, may or may not be THE problem.
always good to know there are many possible causes and solutions for a problem (sarcasm). so can anticipate a good time sorting out which one it is.
so now i've got a few possibilities: worn kingpins and/or bushings, worn out steering box, various worn out steering linkages, toe-out, castor, or bent radius rod.
Old 02-09-2026, 10:27 PM   #13
alchemy
alchemy's Avatar
It would be nice if you said what kind of car you have. If Tim Brown is correct, any rod from 1937 to 1941 will fit. If you live in California, there are probably a dozen within a dozen miles.
I’ve straightened some on my 20 ton H press, and it surely didn’t take all 20 tons. Sneak up on it. You can probably get it back to straight.
alchemy is offline   Reply With Quote
Old 02-10-2026, 12:36 AM   #14
hueyhoolihan
sorry about that...
it's for a 1941 ford deluxe.
Old 02-10-2026, 08:54 AM   #15
Tim Ayers
sorry about that...
You should be able to find a very nice used one fairly easily
Old 02-10-2026, 09:32 AM   #16
Kube
Super Moderator
Kube's Avatar
sorry about that...
private message sent
Old 02-10-2026, 12:49 PM   #17
hueyhoolihan
many thanks!
...don't know if i'll be doing the installation myself. replacing the rear brake backing plate, which involved removing the back end of the radius rod was a miserable job. don't know if i want to "go in there" again, if you know what i mean. ha
