Old 12-13-2025, 07:44 AM   #201
glennpm
glennpm's Avatar
Default Re: Glenn's test for photos
Driveshaft Center Bearing replacement
Old 12-17-2025, 08:36 AM   #202
glennpm
glennpm's Avatar
Columbia Stewart Warner speedo transmission
Old 12-22-2025, 10:16 AM   #203
glennpm
glennpm's Avatar
LZ Columbia Speedo Gears
Old 12-27-2025, 06:43 AM   #204
glennpm
glennpm's Avatar
Column Drop
Old 12-31-2025, 09:12 AM   #205
glennpm
glennpm's Avatar
Block bearings
Old 01-01-2026, 07:55 AM   #206
glennpm
glennpm's Avatar
6 volt headlight relay
Re: 6 volt relays
"I was told a couple weeks ago on Fordbarn that Bosch makes a good one but never found a 6 volt one."
Early 1950-60 VW uses them:
Bosch SPDT
6V 30 amp Relay
0332204001
Used as dimmer relay
In 1950 to 1966 VW
Also listed as:
Merced 0035340245
Porsche PCG61510100
John Deere AR91168
Old 01-09-2026, 11:51 AM   #207
glennpm
glennpm's Avatar
Search post and threads
Old 01-11-2026, 08:12 AM   #208
glennpm
glennpm's Avatar
1946-48 wiring diagram
File Type: jpg 2026_02_09_08_24_41_Ford_Green_Book_ALL_PAGES.pdf_Foxit_PDF_Editor.jpg (12.9 KB, 66 views)
Old 01-23-2026, 02:58 PM   #209
glennpm
glennpm's Avatar
69A Canadien Block
Old 01-28-2026, 07:23 AM   #210
glennpm
glennpm's Avatar
The images below are from the "Green BooK". The length should be 10-1/16" between mounting holes.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 02-01-2026, 08:37 AM   #211
glennpm
glennpm's Avatar
Rear axle ratio
Old 02-01-2026, 10:06 AM   #212
glennpm
glennpm's Avatar
Crab internals
Old 02-08-2026, 08:46 AM   #213
glennpm
glennpm's Avatar
Petronix
Old 02-22-2026, 08:48 AM   #214
glennpm
glennpm's Avatar
water pumps
Rumble Seat’s Notes
Old 02-25-2026, 07:33 AM   #215
glennpm
glennpm's Avatar
Mallory Unilite
Rumble Seat’s Notes
Old 03-02-2026, 09:16 AM   #216
glennpm
glennpm's Avatar
Petronix
Old 03-07-2026, 09:45 AM   #217
glennpm
glennpm's Avatar
Resolution testing
320×480 – Typical for older or smaller smartphones.
larger pics below are 360x480
360×640 – Common for low-end smartphones.
414×896 – Seen on some iPhone models (for example, iPhone 11).
375×812 – Standard for iPhone X and similar models.
412×915 – Popular on mid-range Android smartphones.
Old 03-08-2026, 09:01 AM   #218
glennpm
glennpm's Avatar
VH44 PBR booster
Old 03-17-2026, 07:39 AM   #219
glennpm
glennpm's Avatar
Roadster on frame
Old 03-26-2026, 08:40 AM   #220
glennpm
glennpm's Avatar
32 floor
