Hi all,
I bought a modern distributor from Snyder for my Model A. When I fitted it the rotor arm was pointing at number 2 (according to the numbers on the cap). The engine is at top dead centre on number one cylinder (confirmed with the TDC bolt and visually checking the position of number 1 cylinder and valves. Is it possible to remove the top centre screw and rotate the cam that operates the points to align correctly with number 1 on the cap? |
Hey,
rotating the cam in the distributor won't change anything. As I understand you right, the ignition cables are reversed. Or the distributor is 90 degrees wrong.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version Last edited by Werner; 02-05-2026 at 04:03 PM. |
Bad Back: Yes
Bad Back: Whether you can do that depends on the design of the distributor. If it is like the original Model A one, then YES, it an be done. Otherwise, you may have to use a modern style cap with wire plug leads and connect them accordingly.
A picture of the distributor with the cap off would help.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
Getting close to starting it up (fingers crossed) |
