Old 01-20-2026, 12:27 PM   #38
Doublepumper
Doublepumper's Avatar
Default Re: 40 Ford Ignition Woes
The contacts in the switch aren't robust enough for much amperage draw. A good fix (in my opinion) is to install a relay to power everything up through the switch. Going this route, removes the load on the contacts. The switch now only activates the low amperage relay coil.
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
