Old 01-05-2026, 07:07 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1940s Wheels on mechanical brake Drums??
First 1940's wheels will NOT work on 1936-39 drums.SO if you are using32-35 drums you will need a spacer rings because there are nubs on the drum for the spoke wheel hub.Model A parts vendors might have them.Those nubs will prevent the wheel from sitting flat on the drum surface.
