Old 12-19-2025, 03:49 PM   #21
FortyNiner
FortyNiner's Avatar
Default Re: How many of you do your own work?
I also do most of my own work. Exceptions made for machining and carb/disty rebuilding.
Old 12-19-2025, 03:57 PM   #22
Ronnieroadster
Ronnieroadster's Avatar
Overall I do everything mechanical that includes complete ground up builds. Only things I wont do is body work, paint and upholstery.
This picture is what's on the line bore table at the moment. Ford 8BA block that's getting a five main bearing crankshaft. The next engine for our very fast vintage engine powered land speed race car. Hoping to get near 250 MPH with our 292 cubic inch combination.
What your looking at is a lot of hand made one off pieces using the Bridgeport mill, Southbend lath and Drill press. Oh and a whole lot of hours also.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 12-19-2025, 05:15 PM   #23
Shoebox
Shoebox's Avatar
Originally Posted by rockfla View Post
Bored&Stroked X2
When I got my, new to me, house and shop, 5 + years ago, I told my wife I was going to outfit my shop SO I can do everything I can possibly do, myself. I currently "can" do everything except paint and I am working on that and having my own paint booth. After paying BIG money for a "supposed" professional restoration at a shop in North Georgia and getting a moisture filled paint job....I will be mad with myself and have more money in my pocket than paying someone with NO moral compass or ethics to "screw me"!!!! I have a two post lift, machine shop capabilities - lathe, 2 mills, two ammco brake lathes, 20 ton shop press, a 1 ton gantry crane with a 1 ton electric hoist and 1 ton chain hoist. I have shrinker, stretcher, sheet metal brake, sheet metal shear, bead roller, MiG, TiG and Oxy Acetylene, Sun 504, bead blast cabinet, parts washer, 16.9CFM 80gal compressor, engine run stand and a complete outfitted wood shop SO painting is the last order of business for my shop!!!! AND by and large I don't have to rely on anyone's help to accomplish what I need to accomplish or wait on someone else's scheduled. NOT to be braggadocios by any means
WOW, that is pretty awesome!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is online now   Reply With Quote
Old 12-19-2025, 05:23 PM   #24
RalphG
RalphG's Avatar
My 52 Merc has not been in a repair shop since the 1960s. I do what little work it has had done but I have a secret weapon. My younger brother has decades of experience working as a heavy duty mechanic and when I run into something too complicated or need to borrow a tool I don't have, you know who I'm going to call. I've done all the brake work, shocks, rad replacement, hood and fenders with a little help lifting the heavy stuff. Tire changing. Right now I am stuck on removing an inner door panel hoping to get a new driver window glass.
RalphG is offline   Reply With Quote
Old 12-19-2025, 06:20 PM   #25
Tim Ayers
Bored&Stroked X2
Wow! Good for you, Robert!
Old 12-19-2025, 06:26 PM   #26
Flathead Fever
Flathead Fever's Avatar
I was a professional mechanic for 30-years. Since I was around 18, I have "never" paid somebody to do work on a car except for engine machine work and warranty repair. Nobody touches my cars but me. I worked for the phone company; we had smog licenses for doing smogs in house. We did 100% of everything in house, from fixing the really big trucks that set the poles, down to the small service vehicles. Around one-hundred vehicles were assigned to "each" mechanic to repair and maintain. I did that for 30-years. Every tool we had at my job I have at home. I built a garage that's around 90' long and 30' deep. I have a heavy commercially built hoist and just about every tool I will ever need. I have a paint booth. Big sand blast cabinet, I have little unit for outside sandblasting frames and parts that won't fit in the cabinet. Tire machine and computerized wheel balancer. Brake rotor and drum lathe, hydraulic press... All good quality tools I bought from shops that went out of business over the years.
I collected about a dozen good cars over the years, '32 Fords, 66 GT-350, even a couple early chain-drive Mack trucks. All really neat cars to restore when I retired. Then I retired and I had a failed back surgery, both shoulder surgeries, and then I had a small stroke. Being a professional mechanic really beats the crap out of your body. Now I have everything I need to restore those cars except for a functioning body. I keep thinking I'll go out to the garage tomorrow to work on something but then the pain is too bad. I'm just worn out and I'm only 64.
My dad belonged to the Model A Club since the late 1950s. Before that he had a full race '32 roadster. He bought another real flathead powered highboy '32 roadster that I eventually ended up with. It's up in the air on the hoist waiting for me to go work on it. It ran well until it sat for years at dad's house. I pulled the tank, and sand blasted it inside and out to get the crap out of it. It kept plugging the lines with rust. I just need to get out there and paint the tank and stick it back on the car. I also inherited his '33 disassembled pickup. I already have a '34 pickup project. I have a stock '29 roadster, a couple '64 Falcon projects, a famous magazine Model A Hot Rod pickup from the early 1950s. I think it was the second hot rod to ever have an overhead engine in it when it appeared in Hot Rod Magazine. Another '32 Brookville roadster on an original chassis that's almost finished. There more but can't remember what's all out there until I see it. There's a 200 mph Boss 302 powered El Mirage, Bonneville '29 Roadster out there. And I was going to restore them all, yeah right!
That was me back around 1984. That truck was new then. Years later I put an engine in it, a rear end and a few 5-speeds and clutches over the years. Whatever broke I fixed it and that was just one of many, many phone company vehicles.
Old 12-19-2025, 07:02 PM   #27
52flthed
I’m fairly new to antique cars , since 2019. This is my first and probably my only. 1952 F1. So this will be a different take.
I really try not to do anything if I can help it. �� But somehow I’m always busy or have been busy picking parts up out of state, going to the chrome shop, powder coating, radiator shop, drive shaft shop, dropping parts off-picking them up, shipping them out, reading/researching about them, to say nothing of working at my business in order to pay the high prices for them, sourcing and getting supplies etc. The truck is way too nice for me to be stumbling around with it. Plus I’m really picky about it being in top original mechanical condition. It’s has been through some very unusual problems that even seasoned 50+ years professionals who work exclusively on old vehicles especially old fords have scratched their heads over. So I know this isn’t easy stuff even though I hear everyone at the car show say; “look how simple that engine compartment is to work in!”
Oh sure, I’ve done small projects like restoring the original firewall pad, varnishing the bed boards, and changing out a starter, an oil change etc. But what I do Is assemble all the original parts, a lot of rare accessories, and research the correct parts/ hardware, and shops to use for the given project. I’m extremely involved with the various shops, (i.e. they flip over the open sign when they see me pull up) I’ve used and it’s always been a good collaboration between my mechanics and myself. I always learn a lot from them and they also unbelievably learn from me.
But frankly I don’t have the space, the tools or the talent to be legitimately working on this truck. And I’m happy with that cause it’s turned out beautifully and I’m thrilled driving it. And drive it I do!
52flthed is offline   Reply With Quote
Old 12-19-2025, 07:53 PM   #28
Dr John
I do about 95% or my own work, I don't have a milling machine or machines for extensive sheet metal work. If I can't do it with a hammer and dolly it has to go out. I just bought a sewing machine to do upholstery, will give it a try with the help of You Tube. Lots of good stuff out there if you are selective.
Dr John is offline   Reply With Quote
Old 12-19-2025, 07:54 PM   #29
Tim Ayers
I know this is mainly a purist site, but I am retiring at the end of the month. I've started working with a friend on designing a new performance intake and we've also been discussing designing our own performance cam.
I'm in the process of doing a Lincoln Zephyr distributor V8 conversion using Dean Moon's '53 Car Craft three part series on how to do it at home.
I'm hoping to learn some new skills this year like upholstery and getting better at metal work. I'll even give painting a go.
What is helpful with old Fords is they are not overly complicated and almost every part can be rebuilt or refurbished in some capacity.
I think, like many, the best thing about this hobby is it can help you to keep learning, acquiring new skills and keep your mental acuity sharp.
Old 12-19-2025, 07:55 PM   #30
petehoovie
petehoovie's Avatar
Ronnieroadster
Old 12-19-2025, 08:18 PM   #31
rockfla
rockfla's Avatar
Congratulations Tim. I love metal working, I can’t say I am super good at it BUT I got my English Wheel cheap as well as my bead roller and each time I use them I learn more and more, not only about the tool but how metal reacts and moves. Between YouTube and watching guys on Bitchin Rides and watching guys like Jessie James, I learn and pick things up from watching them!!! My next metal forming tool on my list is a plenishing hammer since I can’t afford a Pullmax…..and work on more metal bumping tools.
Old 12-19-2025, 08:46 PM   #32
big deuce
big deuce's Avatar
Kudos Tim, that's exciting to hear about intake/cam combo! Be sure to keep us posted on the progress. Thanks to these fantastic sites, I have been able to rebuild my 3 speed top loader, manual steering boxes, generators, starters, and latest venture refurbishing a Borg & Beck pp. just need to have it balanced. That again, poses yet another challenge... no one in my community has a balancer for such items. So looking at vintage bubble tire balancing tools. Great thread!
big deuce is offline   Reply With Quote
Old 12-19-2025, 10:34 PM   #33
oldbugger
oldbugger's Avatar
I have always liked working on cars, started as a kid helping my dad, learned the hard way. Worked on everybody else's cars thru high school and most of college. Got drafted into the Army worked in the motor pool. worked on a lot of VWs in Germany. Got back and never stopped working on and fixing VW and Fords. Always did my own work, paint, body and mechanical. Just glad I'm not too fussy. VW parts on the Fords and ford parts on the VWs
oldbugger is offline   Reply With Quote
Old 12-20-2025, 12:26 AM   #34
Ken/Alabama
Ken/Alabama's Avatar
I’ve done it all minus boring and decking a block. Engines, transmissions, rear axles and columbias. Body work, Paint, upholstery, electrical, strobing distributors, installing glass. Have enjoyed the hobby over the last 40 years.
Old 12-20-2025, 12:45 AM   #35
Scotty's 52 F3
Scotty's 52 F3's Avatar
I do ALL my work short of engine machine work and the sewing of upholstery. If I can't get a part or I don't like the price, I fix or fabricate it. Same for tooling. I'm not buying what I can make. I have an old manual lathe and mill and watch youtube a lot. I have MIG and TIG welders, Plasma cutter, tubing bender, etc. Same goes for home projects. Contractors want too much.
Often I really don't feel like doing certain jobs. Once I get a few quote quotes to farm it out, I'm usually shocked at the price and just do it myself.
I worked as a mechanic/welder in the Navy, mining and construction and my last mechanic job was 15 years at a Caterpillar dealership. Learned a LOT working there.
Scotty's 52 F3 is offline   Reply With Quote
Old 12-20-2025, 02:04 AM   #36
rjlester
I do my own work. Just moved to a new acreage and need to build a shop in the spring so right now I'm limited, but once setup again I have a tire machine and balancer, just bought an alignment system (about 25 years old). Have money saved up to buy a couple of hoists. Right now working in a poorly heated small garage.
Worked for a mechanic in high school and my Dad worked on all kinds of stuff so I've had a lot of influence over the years. Lost my job a few years ago so for two months I worked as a mechanic at my friends automotive shop. I was almost as capable as their 30 year experienced mechanic so that really gave me confidence to keep doing what I do at home.
I hate bodywork but have painted a few vehicles with relatively good success. With the price of paint and supplies going up along with labor rates, I may have to start painting my own cars when I get to restoring my cars in the new shop.
The only work I recall sending out has been radiator/heater core repair, engine machining and that kind of thing. I've done the old break the glaze/re-ring an engine from time to time and had great luck. Right now rebuilding a snowmobile engine, new crank and pistons. Got a bunch of snow this week, looking forward to exploring our new neighborhood.
rjlester is offline   Reply With Quote
Old 12-20-2025, 08:07 AM   #37
corvette8n
corvette8n's Avatar
I can take things apart and put them together, dabble in welding, paint, bodywork, machine shop work has to be outsourced.
Old 12-20-2025, 10:08 AM   #38
Model51
Model51's Avatar
I try to do it all myself, but have relied on other for the following:
Body metal work and paint prep
Body painting
Internal Engine work
Radiator repair
Generator and coil rebuilding
Upholstery
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 12-20-2025, 11:00 AM   #39
1942deluxe
1942deluxe's Avatar
Body painting
Radiator repair
Upholstery
Dave,
Pretty much the same for me. I could put a carb kit in, but I can't do what Charlie does. As long as he and Skip are there my stuff will go to them.
Old 12-20-2025, 11:36 AM   #40
cas3
Being a cheap ass, I've always done things myself. From building cars and trucks to buildings and sheds. Plus...thats how we learn! It seems the few times I've hired the "professionals" its been a disappointment. With the exception of Uncle Max, Charle, and Skip Haney of course.
Paint, welding, motors etc, wish I was better at making sheet metal patches, thats an art.
Currently insulating and doing interior walls and ceiling in my new to me 42x48 pole barn to have a good shop again. It goes slow as this old man does not like ladders and scaffolding any more. I have a forklift with a home made man basket as my main helper.
Lots of talented folks here on the barn!
