Old 12-06-2025, 08:08 PM   #21
updraught
updraught's Avatar
Default Re: 19 inch inner tubes
Originally Posted by Model A Man View Post
Update: the tubes didn’t fit. The valve stem were to fat and would not fit through the hole in the rim.
If you drill a bigger hole in the opposite side it will help to balance things out.
updraught is offline   Reply With Quote
Old 12-08-2025, 05:27 PM   #22
ronn
the return shipping isnt worth being bothered. I have installed motorcycle tubes at times in my As with no real problem. On the other hand, bought a chinese tube for my Kubota and the seam gave out 2 months later.
when its cheap sometimes you win and sometimes you lose..........
whats painful is when you pay top dollar and you still lose.
Old 12-08-2025, 05:50 PM   #23
Synchro909
Synchro909's Avatar
The notion that tubes have seems puzzles me. Look closely at one especially on the inside (use an old tube). I defy anybody to find a seem.
The lines on the outside often referred to as a seem are only where different parts of the mold join.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 12-08-2025, 06:20 PM   #24
nkaminar
nkaminar's Avatar
Old tubes make wonderful rubber bands. Slice them to different lengths for different purposes. I used an old bicycle tube to make bands to join three poles together to make a tripod for plants in the garden.
Old 12-11-2025, 03:05 PM   #25
ronn
ask China- the tube had seems,,,,,,,,,,,,,,,,,,,,
seen it with my necked eye! as my HS biology teacher used to say
Old 12-11-2025, 03:36 PM   #26
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Many 19” tractor wheels have an offset stem. I have one I bought that’s top quality, but offset. They said “just keep it, here’s the correct tube”. Any antique tractor owners out there?
Old 12-13-2025, 06:37 PM   #27
BlueSunoco
Originally Posted by Tacoma Bob View Post
................ I promptly purchased Coker's Hartford tubes and through Snyder's tubes in the garbage ............. Just the weight alone of the Hartford is impressive. 14 months and no flats and maybe lose 2 lbs of air in a month or more.
I have talked to SO many people who swear by the Coker Hartford tubes....Those will be what I will buy next time I need tubes
I've been told by the tire guys at our local farm store that Chinese tubes are made from recycled scraps and garbage, made on the cheap, and are total junk. They said tubes coming out of Vietnam use 'virgin' rubber and are well made.
Maybe that is where Coker is getting theirs?
BlueSunoco is offline   Reply With Quote
Old 12-13-2025, 08:45 PM   #28
Bob C
I just got a 600x20 tube from Snyder's and it was Hartford
made in China.
Old 12-13-2025, 10:00 PM   #29
ModelA29
ModelA29's Avatar
This is a lesson in buy once cry once. Every time I look to save money buying something cheaper that may get the job done I end up going back and buying the known product for a few dollars more than what I wasted trying to save a couple bucks - and that's before I add in the time lost........
ModelA29 is offline   Reply With Quote
Old 12-14-2025, 01:30 AM   #30
Y-Blockhead
Y-Blockhead's Avatar
Exactly!
Old 12-14-2025, 03:36 AM   #31
Synchro909
Synchro909's Avatar
If you do as I said in post 23 sometime, you will see that tubes have no seems. How could they and be expected to work?
Old 12-14-2025, 11:41 AM   #32
ursus
Seams seem confusing.
ursus is online now   Reply With Quote
Old 12-14-2025, 01:00 PM   #33
ronn
synchro- when the guy took the new tube out, it was open at one of the seems. following?
Old 12-14-2025, 08:00 PM   #34
Synchro909
Synchro909's Avatar
If there are seems in a tube, how are they sealed? There are NONE! What people confuse with seems is, as I have said, a join in the mold used to make them. Still can't grasp it? Cut an old tube open and look on the INSIDE where there are no molds used and see if you can see a seem. A seem would be visible on both sides.
It seems this seem in a tube is another hard to fix old wives tale.
Old 12-14-2025, 08:13 PM   #35
The Master Cylinder
The Master Cylinder's Avatar
Well it seems to me, seams or not, Chinese tubes are junk.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 12-14-2025, 09:38 PM   #36
David in San Antonio
David in San Antonio's Avatar
I have sections of old inner tubes with slits cut into them to help seal around the floor gaps of the shifter, hand brake, and accelerator.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 12-15-2025, 12:07 AM   #37
Synchro909
Synchro909's Avatar
The Hartford tubes mentioned favourably in post 27 are Chinese - at least that's what they say on the box. I didn't think I would ever be doing this but the Chinese CAN make some good stuff. It is the fault of our buyers always chasing the cheapest price (and therefore quality) that is the problem. I can't fault them for trying to make as bigger profit as possible but there comes a point when they start to undermine themselves.
Old 01-08-2026, 01:03 PM   #38
Model A Man
Model A Man's Avatar
I was able to return them for a refund. I was going to order one from Snyder’s but they don’t tell you in advance what the shipping would be.
Model A Man is offline   Reply With Quote
Old 01-08-2026, 03:07 PM   #39
nkaminar
nkaminar's Avatar
When you continue to checkout there are options for shipping. At that time, if you don't like the shipping cost, you can open the cart and remove everything that you put in there and then sign off.
Old 01-08-2026, 09:27 PM   #40
J Franklin
J Franklin's Avatar
You could arrainge to pick them up at their store.
J Franklin is online now   Reply With Quote
