Hello, I recently bought a 39 ford pickup with original style flathead and 6 volt electrical system.Not my first early Ford, but the first time with this issue. None of the electric gauges work, but the truck starts and runs fine. Going through all the wiring to figure out what was wrong and in the process I realized the battery is installed with negative ground. Obviously this has something to do with the gauges not working, but I wouldn’t think the truck should have started and ran this way (wouldn’t the starter run backwards?). Has anyone seen anything like this before? Is it possible it was converted to negative ground? Or that somehow it ran anyways, but maybe fried something? Not sure if the generator works or not, but I’m pretty hung up over this.
#2 | |
That makes sense. I just looked into how these early starters work. Thank you!
The late great distributor/ignition expert Bubba was adamant that incorrect polarity damages the coil even though it may still work and should be replaced.
i doubt if the battery was charging, as a battery can only charge through the positive battery terminal, regardless of which terminal is used as a ground...i think.
#7 | |
Super Moderator
Kube and Yblockhead are correct. This same thing happend to me on my 36 Dodge pickup. In my case the gauges came back , I hope you fare as well. Tim
I got a 52 Ferguson tractor, which is positive ground, the guy put the battery on, I drve about 5 miles home, noticed it wasn't charging, checked things out, noticed the battery connected backwards, connected it positive ground, started charging, everything was ok
